3.2 Top End Engine Rebuild
Hi Folks,
I bought a 1987 Carrera two years ago. 80,000 miles, very original, very good overall condition.
But it burns oil, about 1 quart per 300 miles. Might need a top end rebuild.
Looking for some guidance on reputable shops in Southern California and ballpark prices, how long it should take, what to look for, etc. I live in Torrance, CA. Much appreciated.
Old 03-11-2024, 04:32 PM
PCA Member since 1988
It shouldn't be burning oil at only 80Kmi. Are you sure it burns oil? You can lose a lot of oil through leaks too. If it doesn't leak, then, yeah, it must be going out the exhaust.
Before you start tearing it apart, get compression and/or leak down measurements.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-12-2024, 12:11 AM
Valve guides worn. Common Carrera issue.
206 637 4071
Old 03-12-2024, 07:00 AM
Tags
1987 , 3.2 , 911 , carrera , engine rebuild
