Originally Posted by icarp View Post
Mike, after the oil ring scratched the Nicasil liners we ran an 800 grit aluminum oxide Hone and we’re able to do a fairly good job but the scratches still remained. We put the engine together with the understanding it would be less than perfect
That’s not to say that we didn’t add a pinch of hope for the possible outcome
I use the same 800 grit hone from brush research, it’s great for deglazing takes about 2 seconds per cylinder and leaves a perfect finish with a low RA. I thought about making a post about it but didn’t feel like starting an argument over it and red scotchbrite.
House producers wanted to end the show after season 8 to keep the enigmatic appeal of the central character and maintain the show's mystique. Ahhh The Mystique!!!
Old 12-29-2024, 06:31 AM
Originally Posted by 911 tweaks View Post
Nice project…
Q any specs and or parts changing since you are back in there…?
You guys got this…!
This will be another eye opener build…!
Carry on…
We are taking a pause until the heads arrive from being ported. We think they’ll be ready and arrive within two weeks.
I think that this build is going to squeeze everything possible out of a 3.2 short stroke.
Increasing CR from 9.8 , Mahle 10.1 CR pistons cylinders. We may be doing dual plugs.
The heads are being ported with Icarp specs, Iconel valves, titanium keepers, drilled for dual plugs etc.,
Keeping the Knightrace75 Camshafts.
The main and rod bearings are coated. Rockers faces, cam lobes and other surfaces have been Izumi treated.
Keeping the PMO 46’s with 42 Chokes.
Keeping the M&K headers and muffler.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 12-29-2024, 03:44 PM
911 tweaks's Avatar
Very nice “tweaks” Shane….!! Thanks for sharing…
I anxiously await how this goes…
Go get em’….!
I live for 911 tweaks...
Old 12-29-2024, 04:00 PM
Did Ian tell you I'm running 200 PSI static compression with the M1 , no problem..
Nikkies cylinders with 9.5 CP pistons without the bottom shim.
Deck was -.067 with shim, -.027 without shim. The valve relief cuts left me plenty of room for the M1 cam so I let the shim out.
Zoom Zoom
I'm not picking my nose..I'm porting my upper intake manifold.
Old 12-30-2024, 02:30 PM
Zoom Zoom
Not static but cranking psi numbers .
The compression test was also done @10ft above sea level
ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 12-31-2024, 06:33 AM
This mornings deck height with base gasket is at -0.047”.
Old 12-31-2024, 08:10 AM
911 tweaks's Avatar
Nice… !
When you get back the heads, can you post pics of where you may of had them tweaked…?
Are you staying with carbs?
Carry on…
Happy New Year to all involved in this Christmas build project…
Bob
Old 12-31-2024, 09:26 AM
PCA Member since 1988
Zoom Zoom
That's slightly below the .030"/.75mm minimum rule of thumb. I've run pistons in other engines with this tight of piston clearance, but the pistons were fairly tight in the bore so they didn't rock much. What piston to cylinder clearance are you using?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-31-2024, 06:41 PM
Jeff Alton's Avatar
What does "fairly tight in the bore" mean? What were the actual measurements for those and what Pistons/Material?
www.turn3autosport.com
Old 12-31-2024, 07:15 PM
These were engines with iron cylinders and cast hypereutectic pistons. 4" bore, clearance .002".
Old 12-31-2024, 09:05 PM
Thumbs up
Better results with .010” base gaskets. - .037”’deck.
Old 01-01-2025, 03:01 PM
Arrow Heads are back.
Old 02-21-2025, 01:53 PM
Arrow
That looks about right.
Old 02-21-2025, 02:50 PM
Decision time.
.037” deck = 10.47 CR
.047” deck = 10.16 CR
Old 02-21-2025, 04:39 PM
Installed the inboard ramps.
Old 02-22-2025, 09:00 AM
Shane, you're using twin plug heads, right? If so, I would go for the tighter squish--.037". I'm at .030", using Mahle pistons with the Carrera domes on them.
IMO, you get more reduction in tendency to detonation with reduced squish/quench clearance than the increase in CR tends towards detonation (but I wouldn't swear to it, because it also depends on combustion chamber shape). Nevertheless, it's a tight balance. If you have the capability, I would consider shaving the piston dome down a bit to get the CR back to 10:1.
David Vizard has some excellent videos on YouTube about quench (he prefers that term), as well as all his other videos. I came across this info initially reading one of his books about 40 years ago, and I have strived to include it in all my types of engine builds since.
Old 02-22-2025, 01:06 PM
Pete, yes twin plug heads. With the head torqued, deck came out to 0.040”, CR comes in around 10.1.
Old 02-22-2025, 04:30 PM
I went with the .50 mm base gaskets. Pistons and cylinders are clipped in.
Old 02-22-2025, 04:33 PM
Ring size…
Looks like a great build. I have a similar build pending - early SC heads & CIS, Max Moritz P&C’s, M1 cams, SSI’s, M&K 2/1, etc..
I am having trouble finding Mahle rings for my build (1.2/1.2/3.0) and due to the hit or miss quality of Total Seal and Goetze rings, I’d really like Mahle rings.
If your rings are original 1.2/1.2/3.0, where did you find them? Were they NOS?
Thanks,
Mark
Old 02-23-2025, 07:30 AM
Thanks,
Mark
Mark,
I bought the Mahle Motorsports kit, it came with the ring pack.
Old 02-23-2025, 02:38 PM
