A few old school engine pix.
2.9 put together by Bill Ring and Eric Wills from pieces I've been collecting for years
Sandcast case
Andial 2.9 p and c
Heads by Steve Weiner (RIP)
Rsr crank
Distributor is one of Aaron Burnhams. The beautiful headers came from Aaron too.
Carillos
Dc64 cams
Lots of other old school bits the sharp eye can see.
Save the gearbox for another post.
Old 06-13-2025, 02:49 PM
Sorry. Rookie. Having pix issues
Old 06-13-2025, 02:54 PM
al lkosmal's Avatar
That is a thing of beauty
RGruppe #669
http://www.x-faktory.com/
Old 06-14-2025, 10:08 AM
It really turned out well. And runs like a champ. 3 oil changes in. Air cleaner setup is per SC/RS.
If I can ever get the tach back, it will have mechanical tach drive
No on engine oil cooler (906 filter instead). Both fenders have coolers and it seems to go just fine.
Old 06-14-2025, 07:21 PM
Originally was going to run w a k-fisch pump but it runs SO well, I think the Bosch pump will stay put?
Old 06-14-2025, 07:24 PM
Nice, I really like the oil lines to the tensioners.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 06-16-2025, 09:35 AM
I believe those are center oiling cams.
Bruce
Old 06-16-2025, 03:46 PM
I bet you’re right.
Old 06-16-2025, 05:15 PM
Try not, Do or Do not
Henry Schmidt's Avatar
It's a hybrid center feed and spray bar cam oiling system. First used in late RSR, 934, 935 and two valve 962.
The interesting thing about this system is that later versions used an extended bolt connection as apposed to a cam flange and nut system used on the Solex cam.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-16-2025, 05:56 PM
Henry wins the prize! This motor was an attempt to clean out as much of the stash as possible.
Old 06-16-2025, 06:56 PM
So, Bill Ring and Eric Wills helped me build this awesome 2.9 engine from a bunch of parts I've been collecting forever. It's got cool stuff like a sandcast case, special pistons and cylinders from Andial, and even heads done by Steve Weiner before he passed away. Plus, it's got parts from Aaron Burnham, like the distributor and headers, and a bunch of other vintage goodies!
Old 06-17-2025, 05:42 AM
PCA Member since 1988
Add center-oiled cams to Henry's wish list for his new engine project.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-17-2025, 02:01 PM
Here is another pic from the front side
Old 06-17-2025, 03:55 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
A friend has a pair of centre oil cams if anyone needs a pair ..
Old 06-18-2025, 03:29 PM
Making center feed cams is relatively easy. Simply get them gun drilled.
The bolts and covers are another story.
Here's a set from a late 935 BOLTS AND A CAM. I think
I can machine the covers to work.
Similar to how we modified the 2.0 covers for Carrera tensioners.
RED: OIL FROM THE CAM TOWER JOURNAL
GREEN: CENTER FEED OIL
YELLOW: ROCKER PAD LUBRICATION
TWO LITER COVER CONVERSION FOR CARRERA TENSIONERS
Henry Schmidt
Ph: 760-728-3062
Old 06-18-2025, 04:12 PM
Banned
That parts list reads like a greatest hits of air-cooled performance. Love seeing Andial and RSR pieces in the same motor.
Old 06-21-2025, 02:47 AM
Had to leave a few bits off because of practicality doubts (used early forged rockers instead of 906) and failing to think ahead (forgot to have the case machined to accept an Rsr main shaft... figured that out when too late)
Old 06-21-2025, 08:01 AM
Pretty kool. Where did you get or how did you make those air cleaner boxes/mounts? I thought SCRS had one piece housing that sat on top of the air horns. Those look like two piece air horns with box bolted between?
Old 06-21-2025, 09:29 PM
My dad (RIP) machined a set up for me, using originals as a pattern. Uses modified factory boats. I think the double entry air cleaner came from Henry? Turned out pretty nice.
Old 06-22-2025, 03:46 AM
