Another engine issue
Hi everyone,
I have a Porsche 911 with a freshly built 2.7 engine.
Specs:
2.7L engine, 9.8:1 compression ratio
2.4S original cams
Ø90mm Mahle pistons
Intake valve: Ø47mm
Exhaust valve: Ø40mm
Intake port: Ø37mm
Exhaust port: Ø35mm
Intake valve lift: 10.5mm
MFI system (no solenoid/cold start)
Cold iridium spark plugs
Fully rebuilt from scratch — 0 hours on it
The engine started fine for the first time. Oil pressure isn’t perfect, but I’m getting around 1.5 bar at idle and 5.5 bar under load when warm, which seems acceptable.I think it's importante to mention that the engine was rebuilt in 2019, and was sitted in a dry place for 6 years until now
Now the issue:
When accelerating (around 2000 rpm and above), I can hear a tickling noise coming from the left bank. There’s also a bit of bluish smoke from that side, but not too much.
I checked:
Compression: all six cylinders are OK
Valve clearances (left side only intake): 0.1 mm
Spark plugs: all dry except cylinder #3, which shows a bit of oil
Also check with camera and cylinder looked OK as far as I could see
Any ideas what could be causing this? What would you check next?
Thanks in advance for any insight!
911T 1970 - For racing purposes only
911E 1973 - For racing purposes only (on going)
Old 10-06-2025, 02:36 PM
Anyone can support me?
Any idea?
Old 10-07-2025, 03:15 PM
Post a video with the noise.
Old 10-07-2025, 08:26 PM
917_Langheck's Avatar
Possibly the valve is sticking slightly open on that cylinder, creating the clicking, but eventually closes by the time of inspection.
Old 10-08-2025, 10:20 AM
Try not, Do or Do not
Henry Schmidt's Avatar
You may be dealing with a valve to piston clearance issue.
The Mahle valve pockets are designed with a pretty close perimeter tolerance. The stock intake valve is 46 mm mm and you state that your intake valve is 47mm. I may be experiencing a slight interference on just one or two valves.
2.4S original cams
Ø90mm Mahle pistons
Intake valve: Ø47mm
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-08-2025, 10:32 AM
I did insert a boroscope and no damage is seen from inside the chamber
Videos for sound and reference
https://youtu.be/Kpym3LuPdZg?si=xHQQHLHfKI8yg2Cy
https://youtu.be/iCW2t6KjsfE?si=zrvkGVuOCsAoC8UQ
Old 10-08-2025, 02:31 PM
PCA Member since 1988
Sounds to me like valve noise from a loose valve or two, so recheck the valve clearances and be sure to make the adjustment at TDC on each cylinder. Yes, there is a procedure for adjusting multiple valves at certain points, but do it by the TDC method to be sure.
Next, it also sounds like it could be loose or blown exhaust gaskets. Check those.
While you have the valve covers off, check for broken head studs.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-08-2025, 11:26 PM
I will check those, but the #3 cylinder spark plug oily (not much) has nothing to do with valve clearance I believe. Blown exhaust gasket can lead to this?
Old 10-09-2025, 02:57 AM
It's a 914 ...
stownsen914's Avatar
You mention compression good. You did a compression test? Did you did a leakdown test? Oily sparkplug could suggest some blowby. Could be unrelated to the oil pressure and valve train noise issues.
Old 10-09-2025, 07:52 AM
Did a compression test, and when cold around 12bar every cylinder.. Believe its satisfatory
Tried to blow air inside the #3, but don't have proper tools to do it. Couldn't ear air leaving from oil tank (don't know if there is any other way to do it)
Old 10-09-2025, 09:50 AM
engine noise
Years ago a rebuilt engine with a substantial clicking noise. We had combined diff pistons, heads etc. Pulled it down and saw nothing, at least at first. We were looking for something glaring due to the noise. What we finally discovered was barely a fingernail shaped crescent shadow on the exhaust valve pocket shoulder. Doesn't take much to make a racket. Bob
Old 10-09-2025, 11:04 AM
Much like the faint trace you can see when a valve diameter is too tight in the valve pocket. Generally, there is only a .040 clearance between the valve and pocket. With a 47 mm valve (as stated) in a piston designed for a 46mm valve the clearance may be too small.
Henry Schmidt
Ph: 760-728-3062
Old 10-09-2025, 11:38 AM
If the valve is interfering with the valve pocket you may be able to feel it by checking valve clearance at overlap. Set each cylinder at overlap TDC, then gently screw in the valve adjusters until they bottom or scrape. Count the turns, each turn = 1mm. If you feel something like scraping or increased resistance, that's probably what's happening. If you don't feel anything odd, and the adjuster screws in freely 1mm or more, then it's unlikely that the valve is touching the piston.
Do this before removing the heads and post your findings.
Old 10-09-2025, 11:09 PM
Can maybe this tickling connect to valve guides?
As I found an oily spark pluc on cylinder #3, maybe it's something out of tolerance
Old 11-17-2025, 10:44 AM
