canna change law physics
red-beard's Avatar
K&N Filters killed my rings ?!?
Spoke with my Engine rebuilder today. The internals in the engine are in exceptionally good shape. He isn't going to, but said he could re-use anything internally.
However...the rings were extremely worn. He suspects dirt from the air supply and the first question he asked me was what filtration system I was using. I said K&N and he said replace them.
Has anyone heard this?
Is there a paper filter available which is the same size/shape as the K&N filter?
Oh - the cylinders are barely in spec, soooo I decided to go with replacements.....2.7RS...and the T cams are being replaced with the 2.7RS S cams - factory new! THANKS EBS!
Any one have Carb part reccomendations for this motor?
James
James
Red-beard for President, 2020
Old 09-19-2003, 02:54 PM
Bill Verburg's Avatar
Yes, thats why I refuse to use anything but the factory filters.
The last 2 engines i've had in my car.
When I raced M/X and TT we tried the oiled foam filters and had no end of trouble. Factory dry paper didn't solve the problem but did improve the situation a lot.
Bill Verburg
Old 09-19-2003, 03:09 PM
Senior Member
Doug Zielke's Avatar
Proponents of K & N (Krappy) filters will defend them like it's religion. But the fact is they allow much more dirt to pass into the motor.
Want proof (before your rings are worn out)??....
Just remove your Krappy filter, take a bit of grease or oil and coat the interior of the airbox; replace Krappy filter. Now go for a short drive on gravel road. (While you're driving, the fan is sucking in large amounts of dust-laden air).
Now, check the airbox, using a paper towel to wipe up all the dirt that made it past the Krappy filter. Makes you feel real good, don't it?
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 09-19-2003, 06:59 PM
Bill wrote:
"When I raced M/X and TT we tried the oiled foam filters and had no end of trouble. Factory dry paper didn't solve the problem but did improve the situation a lot."
Bill. What was wrong with either material?
Sherwood
Old 09-19-2003, 09:09 PM
We would actuallly find grit on the engine side of the filters, rings and cyl. bores would show p[ronounced wear after only a wekend or two.
The problem was more pronounced on the 2 strokes.
Admittedly the environment was as bad as it gets but the paper elements though they needed changing often worked better.
Bill Verburg
Old 09-20-2003, 03:58 AM
Party Member
viejopatron's Avatar
Here's my dos centavos...
Could it be blow-by around the filter? Any filter or strainer is only as good as the installation.
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 09-20-2003, 07:12 PM
Here's your change
No
Bill Verburg
Old 09-20-2003, 08:24 PM
ASE Master Tech - 35 yrs
larrym's Avatar
you WERE using KN oil? dry kn's are worse than paper..
Uniflow (motorcycle folks) also have a "sticky" oil they use .. I am using 2 of those on my MGB vintage racer
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 09-20-2003, 09:54 PM
beepbeep's Avatar
Yupp, open washable/oilable conical filters filter poorly. Ricers like them beacuse of extra sound though.
I have seen a turbocharged car whose impeller was sanded-down by all debris in the "filtered" air...
Thank you for your time,
Old 09-21-2003, 04:52 AM
red-beard's Avatar
Are there filter which will fit the housing, but made of paper?
James
James
Old 09-21-2003, 09:44 PM
Doug Zielke
SCWDP President
911pcars
Bill Verburg
beepbeep
HP junkie
red-beard
My Turn...
I've posted about my hard data oil analysis silicone content with K&N compared to stock on a CIS more than once. And I had the big dirt road pic in Nevada to run the stock paper to extremes to for the comparison.. [if needed plug in name and K&N]
So the K&N was only run on metro NYC clean roads, and the stock on extreme dirt/no hard surface. both started with fresh oil.. and the K&N lost.. and I have hard info to prove it if you need a copy of the oil analysis..
and if the foam matters for routine ricers between a 150k mi engine and a 100k mi engine who cares.. I don't have that luxury.
So...
I'm prepping a carb install and only have the WaterShields with K&N.. and I don't want the stock housing contraption for paper.
Can anyone pry me away from my beloved K&Ns.. Huh .......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-21-2003, 11:21 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Aren't there alternatives to K&N cone filters now, i thought other companies did there own thing now?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 09-23-2003, 09:19 PM
Hold a K&N up to a light, you can darn near see right through it! factory paper element for me..
Old 09-25-2003, 11:40 AM
"Are there filter which will fit the housing, but made of paper?
I searched a few years ago for a paper filter the same size - couldn't find one. If you want to search what's currently out there, look for an element OD of 12" and height of around 4" or so. You can form a round filter into an oval to fit the housing. Let us know what you discover.
BTW, there's another current thread that discusses K&N replacement alternatives.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 09-25-2003, 01:00 PM
I realize the K & N don"t filter as well as a stock paper one.
On my turbo car I use the paper filter only. On my race car I run the K & N. On my daily driver (Toyota with 225k) I have only run the K & N with a good amount of air filter oil.
Tinker
Old 09-26-2003, 09:59 PM
Cool
"So...
Can anyone pry me away from my beloved K&Ns.. Huh .......Ron"
had to quote myself
So. I think it's Crager who uses K&N socks on his Webers.. it's a foam covering made of something. it's in his thread.
I need a bright idea. my last bright idea melted 2 headlight filament grounds within 2 minutes of each other..
but I think I'll have to create something ...............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-26-2003, 10:41 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Bill, if your bikes are getting dirt past the filter, then it's not oiled or installed correctly. Period. My KTMs and KX's airboxes are so clean you could eat out of them. So's everybody elses that I ride with. Why would the manufacturers put oiled foam in them in the first place? Paper filters in a dirt bike? You'd go broke....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 09-30-2003, 02:39 PM
Dept store Quartermaster
lendaddy's Avatar
I raced MX for years and had ZERO troubled with oiled foam filters.
I did however clean and reoil after every weekend.
Cornpoppin' Pony Soldier
Old 10-07-2003, 08:39 AM
