Insane Dutchman
What size of TWM Throttle body to use?
Hi, just doing the planning for my next engine. It will be based on a 930/03 case, using the 98 mm Mahle P/C combo with the stock SC crankshaft, S cams. Car will be dual plugged and will have SSI exhaust, single outlet muffler.
Car will be a street machine, perhaps occasional track days, but will primarily be used for touring around in my "twilight years" which are rapidly approaching.
Intent is to use the TWM "Weber carburetor replacement" throttle bodies along with something like a TEC 3 engine management system.
Any advice as to the proper diameter of throttle bodies to select for best all around performance?
Dennis
Old 02-08-2004, 08:15 AM
No Expert
jgparker's Avatar
Wow, that TWM throttle body set-up looks great. Can I ask how much you expect the TWM TB plus the TEC3 FI to cost?
Thanks,
JP
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-08-2004, 08:49 AM
No Expert
jgparker's Avatar
This is what I was looking at:
http://www.twminduction.com/ThrottleBody/ThrottleBody3006-FR.html
Old 02-08-2004, 08:53 AM
Bill Verburg's Avatar
Sounds like a very nice setup, wish I knew the answer but keep us apprised.
Bill Verburg
Old 02-08-2004, 09:33 AM
Stay away from my Member
campbellcj's Avatar
Richard Clewett would be good to chat with re. your planned setup. He sells the parts and should have a good idea of what works well with what engines.
http://www.clewett.com/
No affiliation, just passing along the info...
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 02-08-2004, 10:14 AM
Navin Johnson
TimT's Avatar
heres mine (shameless pic plug)
sizing isnt as critical with throttle bodies as with carbs...no venturi
44 should be fine...if not 48's.. last time I talked with TWM the 44's were a few weeks until they made some more..
'69 911 GT-5
'75 914 GT-3
and others
Old 02-08-2004, 10:20 AM
Insane Dutchman
I guess I was planning on using the 3003 series which is at - http://www.twminduction.com/ThrottleBody/ThrottleBody3006-FR.html - which says they are available in 40, 44, 46 and 48 mm sizes. The inidividual throttle body set up is indeed gorgeous, but more than what I need and definitely more pricey...although sizing ought to be the same.
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 02-08-2004, 10:55 AM
Navin Johnson
TimT's Avatar
but they are the smallest you can get.
errrrrr NO
available sizes 40,44,46,48
Ordering Guide
Order by Series number, bore size and whether left or right example: 3003-4403/L where 3003 is the Series, 44 is the bore size in mm, 3 is the number of injectors, left indicates shaft without TPS drive.
Throttle sizes available 40, 44, 46 48 mm
Please note the 3003 Series is the only TWM throttle body where 'left' does not indicate the switch drive unit.
Everytime I talk to TWM its like im talking to crocodile dundee, kinda like the motec or Link folks...
all of the above are from the same castings..
'69 911 GT-5
'75 914 GT-3
and others
Old 02-08-2004, 07:07 PM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Dennis, take also a look at this company http://www.jenvey.co.uk, the price seems reasonable.. and they have a couple of distributors in Canada...
My next year (or so) project goes along the same lines as yours... but I will be using the MegaSquirt engine management.
Keep us posted!!
regards
Jordi Riera
'84 930 (modified)
Old 02-08-2004, 09:54 PM
