1987CarreraKid
Guest
Posts: n/a
3.2L 911 Turbo Setups?
Has Anyone on the board ever done a 3.2L turbo setup?
I have a 87 911 Carrera 3.2 and the engine has almost 213k miles on it. I drive this car every day, and am planning on rebuilding it this summer. The only prblem is that i am having trouble deciding what type of a setup to do. I will be basically using the car for track and drag use, but still want to be able to drive it on the street.
If anyone has done a turbo setup on a 3.2 please list the difficulty of the task and what things were needed to be chnged for it to work besides lowering the compression. Im just getting into all this, and my knowledge isnt too good yet, so lol... However i have gained some knowledge from Waynes books, so at least i can always refer to them if needed.
No matter what route i decide to take i will probably get rid of the fuel injection for carbs, or many individual throttle bodies.
thanks for the help in advance.
-Riley
Old 05-04-2004, 09:11 PM
Irrationally exuberant
ChrisBennet's Avatar
I know "Mike the Mechanic" and "juan ruiz" have done this. Use the Search button (upper right corner of this page) and you'll find a some more.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-05-2004, 05:47 AM
Navin Johnson
TimT's Avatar
Ive been involved with a few 3.2 to 3.2 turbo conversions. Its reallya pretty straight forward project (or it is now after a few of these conversions). This is NOT an inexpensive project though!!
youll have to:
*get the drivers side cam machined for a scavenge pump
*get a scavenge pump
*Have an intercooler made
*get a set of headers
*get a turbo
*modify the oil tank to accept oil from the scavenge pump
*lower the c/r
*replace the motronic with another EFI system
Since your engine has 231K on it add all the above to the price of a basic engine overhaul!!
All the hardware should be relpaced with premium stuff ie ARP or Race Ware. The connecting rods should be replaced with Carillo, or Pauter rods....
Then after everything is buttoned back up, you have to map the EFI figure a few(more than a few if from scratch) hours for that.
Im sure I left something out.... There are 3 of these coversions in various states of completion in my friends shop now
'69 911 GT-5
'75 914 GT-3
and others
Old 05-05-2004, 10:20 AM
Author of "101 Projects"
Wayne 962's Avatar
Forced induction engines should be designed from the ground up - not necessarily have a turbo simply bolted on. You really need to swap out the pistons/cylinders, and upgrade the fuel injection to a programmable one...
-Wayne
Old 05-05-2004, 12:39 PM
1987CarreraKid
Guest
Posts: n/a
Thanks guys, i have spent a while now today looking up some setups. Thanks for the help, ill be sure to post what i decide what to do when i figure it all out.
-Riley
Old 05-05-2004, 02:43 PM
Navin Johnson
TimT's Avatar
I knew I forgot something...
you will have to get a fuel pump, or a supplement to your existing fuel pump, to keep up with the demand of the new engine..
You will also need a wastegate, and appropriate blow off valve..
If your doing this build yourself you obviously take the labor out of the equation, the cost of parts alone will make you take a real deep breath....
A rough figure of $12000 in parts alone isnt out of the question....
'69 911 GT-5
'75 914 GT-3
and others
Old 05-05-2004, 07:42 PM
WydRyd's Avatar
Yup, I've done this bolt-on conversion and it's very straight-forward
Interface a turbocharger to the factory heat exchangers via a J-Pipe, locating turbo on the side of the engine
Use a custom Motronic CHIP
Use a Wastegate preset to 0.5bar (non-intercooled), or 0.7bar (Intercooled)
Use a blow-off valve
If intercooled, fabricate the appropriate intake plumbing
Use a rising rate, boost sensitive fuel pressure regulator
No need for electric scavange pump, use gravity oil drain to lower cam cover
Plumb intake straight into the Air Flow Meter and away you go.
Mike, Juan and I all had the same system on our cars running 0.7bar at factory 9.5:1 Compression.
My engine has just been torn apart to go to stage 3 power levels and everything internally was in perfect condition (bearings, piston rings, valve guides etc).
If you have a Euro spec 10.5:1 Carrera Engine, you have no option but to open her up to lower C/R, but for the US spec model, it can be a bolt-on conversion.
U need the right CHIP though!
Hope this helps!
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-11-2004, 06:33 AM
adomakin's Avatar
0.7 and 9.5-1? jesus!
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 05-11-2004, 10:41 AM
beepbeep's Avatar
There are cars boosting 1.3 on 9.4:1 out of factory ;-)
Equipped with 4 valve /cylinder and knock-sensors though...
Thank you for your time,
Old 05-11-2004, 03:15 PM
WydRyd's Avatar
hehe, well, you have to remember that this is achieved using custom Motronic software that takes care of the ignition timing under boost and also utilises a 900 cubic inch intercooler. Intercooler size and efficiency plays a huge role in assuring intake temps are kept under control and minimises the chance of detonation.
You cannot go any higher than 0.7bar at that C/R. Any higher and you are heading for the big bang.
Having said all of this, 1987carrerakid's engine has some pretty significant miles on it, so I wouldn't perform a bolt-on mod like this to his tired engine (mine only had 65k miles when I did this conversion). He'd need a top end overhaul with new valve guides & piston rings and if he's going to go into the engine anyway, why not fit a custom set of JE's in there OR if cost is prohibitive, lower the compression by using thicker head and base gaskets for ~8.5:1 C/R to run approx 0.85-0.9bar
Just some recommendations
Merv
'89 911 Turbo Cab
Old 05-11-2004, 05:12 PM
juan ruiz's Avatar
Oh those good old days............... All I have to said, that is a FUN set up, and the key for that sucess is the Chip and make no mistake not any chip.
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 05-11-2004, 05:59 PM
WydRyd's Avatar
Hi Juan, or should I say "MasterHP"?
What's the status with your MONSTER?
Hey, are you running a T60-1?
Merv
'89 911 Turbo Cab
Old 05-11-2004, 07:07 PM
1987CarreraKid
Guest
Posts: n/a
Hmm, well i hav decided to not go the turbo route. Im only 17 and there are many many year in the future for me to mess around with that later on. I decided to go with the 3.5 N/A, and i want to do a Individual throttle body setup also. I still have quite a bit of money to save up for this.. so its gonna be a while. Thanks again for all the info though on the turbo setup, ill have to do one for sure on a 3.2 in the future.
Old 05-11-2004, 10:57 PM
juan ruiz's Avatar
Hello Merv, we stop running the 60 longgggg ago since then I have try 5 different combinations and we are testing # 6 now.
10.76@139-1/4 mile
0-1 mile 193MPH
Old 05-12-2004, 04:39 AM
3.2 turbo'd
Anyone still around from the back years, regarding boosting a 3.2L 1987 engine?
Looking for details, or maybe even your castoff setup already fabricated for bolton. Only want to bolt on a mild boost, to have 300-320hp.
Anyone?
I mean DETAILS - where to mount, plumbing, wiring, what to buy, how/where to get fabrication done, tuning, etc.
There's a lot of information out there, and it's frankly too much and too overwhelming. All I want is 300hp increase, bolt on assembly; no controversy or complications about which is better, etc.
Thanks.
Old 07-06-2012, 06:13 PM
Can i use a 3.3 turbo intake manifold for 3.2?
How about the 3.3 exhaust setup with turbo for 3.2?
I want to do the same thing on my 3.2 and i have lots of parts from a 3.3 turbo
Old 10-22-2012, 04:45 PM
