Is piston repair possible?
As you may have heard I recently dropped a valve in my 2.7 race motor. So far the damage appears limited to #1 head and piston.
The pistons are Arias forged AL 10.5:1 - my mechanic ordered them years ago for a customer who no showed and I bought them last year when building a new 7R cased engine.
They have a high wedge dome with valve pockets. The damaged piston has pretty deep gouge marks from the bit of valve that fell into the comb'n chamber.
I fear it will be very difficult to replace one piston. When the teardown is compete I plan to call Arias and ask if I can send them a good piston to copy.
I know its a long shot but is there any way the piston surface could be repaired? For example, could you weld over the dents and re-machine the top face?
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 12-20-2004, 10:13 PM
Still Doin Time
asphaltgambler's Avatar
It would depend on the severity and amount of damage. I'm sure that this piston is forged and not cast. Either way you can't 'weld' the damaged area to the crown.
Post some pics here and lets see how bad it is. Arias may still have these lying around or they may have a dealer network that may still have them in stock. You would still have to buy a set, possibly 10 units if they are rare. If none are available they may tool up for another set, but again they usually do 10 at a time minimum
Alternate route may be different manufacturer and again replace the set.
Old 12-21-2004, 07:10 AM
Try not, Do or Do not
Henry Schmidt's Avatar
SMOKE, RATTLE AND ROLL
There is no way to properly repair a damaged piston. Even with a minor impact you run the risk of unseen structural of damage. Throw the Arias pistons away and replace them with a quality part. My thought would be Mahle or JE.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-21-2004, 09:54 AM
Bet that engine sounded like it had six bad rod bearings when it was running.
Old 12-21-2004, 12:42 PM
Bill Verburg's Avatar
I am not recomminding this but years ago I was at a race where I burned a hole in one piston during tuning and qualifing. There was no replacememnt immediately available so a machinist/welder buddy welded it up, I kid you not. Not only did it last the remainder of the weekend, but the remainder of the season as well. It was replaced out of guilt the following winter.
yrmv
Bill Verburg
Old 12-21-2004, 01:33 PM
Thanks guys - I didn't think it was possible, or even a good idea - but just wanted to make sure. I'll post some pics of the piston when we get it out. Here's a pic of #1 head.
ps: mpdevelopment re - "Bet that engine sounded like it had six bad rod bearings when it was running."
A. what makes you think that? - the engine has been fantastic for a year.
B. how does this answer the qn - or even add to the discussion?
Cheers, Ryan
Old 12-21-2004, 01:45 PM
Sorry no harm ment I have run arias pistons in the past and they run such loose clearences that they rattle badly.
Old 12-21-2004, 02:03 PM
mpd - that's cool, thanks. i was a little confused.
nobody knows much about these things down here (australia) so i'm searching for any and all info (good or bad)
Cheers, Ryan
Old 12-21-2004, 02:14 PM
350HP930's Avatar
While some minor surface melting and filling to fix a few blemishes is acceptable, judging by the pic of the head I say replace it.
Old 12-21-2004, 02:53 PM
Navin Johnson
TimT's Avatar
I used Arias pistons in an engine I built years ago. I had an "event" that required replacement of one piston. Arias was able to supply me with a piston that matched. I sent them one of the good pistons, and they copied it for me. Never had a problem with piston slap with them either.
'69 911 GT-5
'75 914 GT-3
and others
Old 12-21-2004, 11:47 PM
Super Moderator
cstreit's Avatar
"Just a flesh wound" eh Wayne?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-22-2004, 07:08 AM
Still Doin Time
Man, I'll bet that the intake side flows well now!!
Old 12-22-2004, 07:37 AM
even though it blew about 500m from the end of the stage - we still dragged it over the line
you do strange things when you're competing...
Cheers, Ryan
Old 12-22-2004, 01:23 PM
350HP930's Avatar
How fast was the engine turning over when this happened?
Old 12-22-2004, 03:12 PM
350
its all a bit of a mystery - the dropped valve has all the signs of a mis-shift overrev. I do not recall any overrev's during the event we were in. plus i know my 7200 rpm rotor button rev limiter works.
however, I have done a bunch of events over the past year with this engine (including a 5 day rally) and I think it may have happened earlier and put a little bend in the valve which then eventually failed after numerous cycles. the end of the valve also shows signs of a propagating crack then a brittle failure of maybe 20% cross section.
we were going uphill in 3rd when the engine lost a lot of power - and then the racket started about 100m later...
its being fully stripped as we speak, new valves, new springs, new etc etc $$$
Cheers, Ryan
Old 12-22-2004, 03:22 PM
MBAtarga's Avatar
Send the head to MM, they might be able to re-condition it - good as new!
Mark
'83 SC Targa - since 5/5/2001
Old 12-22-2004, 08:13 PM
jluetjen's Avatar
It's not the overrev on the up-shift that kills a motor, it's the over-rev on a downshift that will toast it. And there isn't a rotor-button around that will protect against that.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 12-23-2004, 03:31 AM
Still Doin Time
I just did a complete engine on a '98 BMW M3. The kid just installed a new short-shifter and was speed shifting from 2nd to 3rd but rammed it up into 1st instead!! Clutch out, huge RPM, all valves smash into pistons!!
Took him 10 months to save enough to pay for it!!
Old 12-23-2004, 06:56 AM
