Increasing compression?
Is it possible to increase my compression just by shaving the heads. I have a 1978sc and would like ot do a few more mods. Maybe go to twin plugs also.
Doesn't want/need a 3.6L
Re: Increasing compression?
Ralph |
How much could I get away with on a stock sc. And go to twin plugs. Still have cis and engine has 964cams .
Irrationally exuberant
You won't need twin plugs for the small compression increase you would get from milling the heads. If you have the budget for twin plugging (an expensive proposition) I'd spend it on 98mm P&C's and make a 3.2 instead.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
