Alter Ego Racing
ErVikingo's Avatar
Without external cooling you are limiting the possibilities greatly. I had some radical thoughts but those require some nice coolers to keep things in check.... That's the subject of another conversation, perhaps for that 71 E PCA racer
In your shoes, I'd opt to get some Nickies due to the improved heat management (material, extra fins, ...) and perhaps consider overdriving the fan (knowing that there is a possibility of cavitation).
I'd also consider some of Sherwood's heat barriers (anything to keep heat away from the engine) and perhaps some creative use of underbody airflow. In this app. I think squirters would not be a must but would be nice and can't hurt).
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 02-21-2007, 11:30 AM
JCF JCF is offline
Please, don't stop.
Du must schwein haben
'67 901/05 rebuilt 2.2
Bultaco Metralla 62 "XDina"
'68 BMW R69S
Old 02-22-2007, 04:12 AM
Grady Clay's Avatar
John,
Remember, the fan ratio can negate the necessity for a front cooler on a “small” engine and you can change back & forth fans & pulleys without removing the engine. I have 1.82:1 on my 2.0 and 2.8S (of course the 2.8S needs the Rubbermaid Solution for track.)
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-02-2007, 07:01 PM
Blake Meredith's Avatar
The engine that I put in my 914 has a 2.4L crank with the 87.5 mm pistons with the Nickes. It has 46-40 valves with 36mm ports. GE 40 cams. I have 10 to 1 comp. I have not finished tuning it yet but is making 170whp and 160wtq at 5800 rpm. I have not dynoed it past that yet. I also do not have the 36mm manifolds for the carbs yet. Still looking for some. I hope to see almost 200 hp at the wheels when all is said and done.
Blake
Old 03-03-2007, 05:01 PM
Doc Speed
Neil '67 911S's Avatar
Originally Posted by Grady Clay View Post
John,
Best,
Grady
What is/was the Rubber Maid solution?
Thanks!
- Neil
'67 911S (Ol' Ivory)
'82 Hewlett Packard 34C
Old 04-05-2010, 06:11 PM
Max Sluiter
Flieger's Avatar
Spray water from a tupperware tub onto the cylinder heads or into the fan.
Old 04-05-2010, 06:59 PM
Have anyone tried Cheap Cylinder/piston sets?
Hi ,
I am Restoring a 68 911, The body has been lengthened to 69 spec, and is near all complete. I’m now turning my focus to the engine.
I have a 2.2 t all in tact that has been running but is need of a ring and valve refresh.
I also have a 2.4E that was rebuilt several years back but the previous owner let water get into a cylinder which cracked one cylinder.
My question is has anyone used those cheap cylinder/pistion set found on ebay?
My preference is to have the 2.4E as my engine.
I also see 2.2E cylinder/pistons sets for sale will these work?
I appreciate your reply
Old 06-11-2010, 05:53 PM
304065's Avatar
It has all come full circle here:
Assembling 1966 901/05 Engine: Phase V- The Final Exam
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-17-2012, 10:37 AM
Tags
901/05 , john cramer rebuild
