Life moves pretty fast.
quint22cp's Avatar
Pelican Parts SSI heat exchangers for 3.4?
During my engine rebuild I want to fit some SSI heat exchangers:- PEL-SSI-LT3.2 & PEL-SSI-RT3.2
I will also be increasing the capacity to 3.4L, are the primaries on these heat exchangers big enough to cope with this?
Has any one gone down this route?
Old 06-29-2005, 11:36 AM
Bill Verburg's Avatar
from my personal experience SSI are fine for 3, getting too small for 3.2 and definitely too small for 3.6
All SSI have 1 3/8" primaries, I would look for 1 1/2" or maybe even 1 5/8" depends on other mods and intended use.
Bill Verburg
Old 06-29-2005, 01:28 PM
quint22cp's Avatar
I gott'a have heat this is the UK!
Summer only lasts 4 days and we just had them.
Are there any other SSI style heat exchangers on the market with bigger tubing?
Twin plugging, you know it makes sense
Old 06-30-2005, 01:52 AM
B&B has both 1 5/8" OD and 1 3/4" OD w/ heat that bolts on. Or since you are in the UK Hayward &Scott may be able to help you.
A word of warning, the B&B headers are fine but do have a proprietary spacing for the muffler inlets. I wouldn't use the b&B mufflers too many headaches there. Fab up a Flo-master or equivalent.
something like this
Bill Verburg
Old 06-30-2005, 05:00 AM
MBruns for President
JeremyD's Avatar
A question and a statement.
Question - Bill where did you get the heat set ups (especially the rears) Is that a B & B part.
Statement - Ben McFarland will be in receipt of a B & B muffler from me and will be making mufflers at some point for B & B headers.
Old 07-03-2005, 08:21 PM
When you order B&B headers you have several options
  • 1 5/8" or 1 3/4"
  • Carrera 3.2 heat inlets or 964 heat inlets
  • 911 heat outlets or 964 heat outlets
Mine are 1 3/4", 964 heat inlets and 911 heat outlets.
w/ that setup you use the stock 964 heat tube as pictured. I have used it on both 964 and 993 vram engines.
Bill Verburg
Old 07-04-2005, 05:22 AM
JeremyD's Avatar
Great 0 thanks Bill - I have the 964 version - I'll have to look for a 964 heater cross over tube.
Old 07-04-2005, 05:29 AM
quint22cp's Avatar
Bill,
Where did you buy your B&B?
I work in the US quite alot and I was going to buy them out there and carry them home.
Exchange rate is good at the moment!
Old 07-04-2005, 05:32 AM
JeremyD's Avatar
Pelican Parts is a B & B Dealer -
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_exhaus_pg2.htm#item6
Steve Timmins at Instant G is also B & B Dealer - timmins@UDel.Edu
Old 07-04-2005, 05:38 AM
