goldgunner's Avatar
I.D. This ENGINE STAND
Can anybody identify this engine stand - as to manufacturer and/or model number?
Looks like it takes the Porsche engine yoke mounting shaft as if it were made to...no adapters necessary.
Also note that it doesn't have the wide surrounding flange for the typical engine adapter - seems to be almost perfect with no wasted capability.
Thanks!
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 08-04-2005, 10:38 AM
goldgunner's Avatar
Well heck...here's the pic
Old 08-04-2005, 11:15 AM
Forced Induction Junkie
WERK I's Avatar
I bought one like that at Pep Boys...it was red, though. The yoke shaft did not fit perfectly on the stand, but if you cut up a gallon milk carton, poly type, and wrap the material around the shaft, it will shim perfectly and allows the yoke to turn freely.
This was one of Chris Bennet's tech tip ideas.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 08-04-2005, 11:32 AM
rw7810's Avatar
Looks like the standard engine stand to me with a three point base converted to 4 point. Same as the one I used recently.
Robert Williams
70' 911T
Old 08-04-2005, 11:35 AM
Irrationally exuberant
ChrisBennet's Avatar
The way that is modified looks like it would be weaker than the orginal 3 point setup. I'd be a little nervous using it.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-04-2005, 12:42 PM
Ditto from me....the connections at the welds for the 4 point conversion do not look good to me at all. Not enough gusseting/etc. The stands I've seen and I used was a three point and the out riggers making it into a four point was one big beam with casters coming off the end of the three point leg. This gives you the "factory" weld connection that is holding this thing up....which in your case has been eliminated. I don't want to read that the engine fell into your lap. In addition you can see that the "legs" are already flexing.....these may not fail but it indicates that the welds have considerable stress. I hope this is stated strong enough.
-h
Sold: 1989 3.2 coupe, 112k miles
Old 08-05-2005, 07:23 AM
I've seen some really horrid engine stands where the parts that were supposed to fit together had a 1/4" of gaps. There was so much slop that the upright part of the stand tilted so far over that the engine would have slid out of the stand if we hadn't wedged pieces of steel in the joints to tighten the fit. If I was buying a stand today I would get it from someplace locally so I could take it right back if necessary.
-Chris
Old 08-05-2005, 07:38 AM
Jim,
I hope you take the engine off the stand and get it properly modified or get a different one. I think we want to avoid you having an incident where you would want to take it back... at that point you may have damaged parts you can't get from EBS but could be covered by insurance.
-h
Old 08-05-2005, 02:42 PM
goldgunner's Avatar
Actually I'm at the stage of shopping for an engine stand - the pics not mine - just one that looked pretty good to me...but clearly you experienced types have shot it down...oh well...
So, the new question:
Recommend an engine stand that accepts the Porsche Engine mount complete with the full yoke and most importantly the cylinder: the goal being without modification.
Thanks again!
Jim
Old 08-05-2005, 02:46 PM
Walt Fricke's Avatar
Porsche Crest
Jim - I had an inexpensive, bolt together, auto parts store T stand. When I got tired of the compromises involved with the yoke which came with it (four moveable arms) I bought the Porsche yoke and the holder that gets bolted to a workbench or stand. I figured I'd modify my stand so I could bolt the holder to it. However, the yoke fit well enough as it was, so I didn't need the holder part. I drilled a hole through the tube on the parts store stand so I could use the 90 degree holes in the factory yoke to hold things in the orientation I wanted.
My guess is that most stands have about the same diameter tube for their "holder," and the Porsche part will fit well enough (with or without some shimming). So just get the OD measurement for the Porsche part (or one of the aftermarket substitutes), and go stand shopping.
Walt Fricke
(who eventually bolted the factory holder to a workbench, so it wasn't a total waste)
Old 08-05-2005, 05:35 PM
goldgunner's Avatar
Thanks Walt - I may go right to mounting on the workbench also. I have the factory holder and a very sturdy workbench - but there goes half the bench! A Stand would be so much more flexible as to space and arranging (or rearranging) things.
Jim Disharoon
Old 08-05-2005, 06:05 PM
MBruns for President
JeremyD's Avatar
I bought the Good year one at Sams...
Old 08-05-2005, 06:52 PM
Looks like a modified version of the one they sell at HarborFreight.
'82 911SC
Old 08-05-2005, 07:28 PM
HarborFreight link...
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=32915
I've got my engine on the harbor freight stand and it works great.
'82 911SC
Old 08-05-2005, 07:31 PM
JeremyD's Avatar
Have a picture here somewhere
Old 08-05-2005, 07:35 PM
JeremyD's Avatar
Mine was $56 and it folds up -
Old 08-05-2005, 07:44 PM
Goodyear looks good to me...has 4 points.
Harbor Freight (Hampton 82SC) looks marginal no 4 points. A method to determine that stablility...draw a line on the floor around the contact patches with the casters tucked in...estimate the worst case center of gravity of a built up engine and and see where this lands on the floor, it needs to be way inside of the lines on the floor. If you look at the Hampton pic. there is not much distance.
I suggest the 4 point version so you don't spend all your time making things and not working on the engine.
-h
Old 08-06-2005, 06:47 AM
trak ratt's Avatar
Looks like someone modified a standard stand with a couple of legs. That would likely allow the engine to spin 360 (unlike most shorter, less expensive stands) and a firm base for moving around the shop and holding a drain plan. Doesn’t seem like that bad an idea!
Old 08-06-2005, 07:09 PM
goldgunner's Avatar
Went today and bought the Sam's Club Goodyear Racing 4 wheel/2legger. Daughter assembled it while I hung the wench - I'd already attached the Porsche yolk to the engine.
The yolk round didn't exactly slide into the engine stand round...took some - ok plenty - of hammer blows to the engine stand vertical member just below the round receptical, but it finally went in.
Turns and balances well, everything thing is peaches at this point.
Of course, this Goodyear setup is a little low...the old back will be bending more working on the long block than preferred...
Thanks all
Jim
Old 08-06-2005, 07:31 PM
dweymer's Avatar
Now go buy a stool that rolls, and has a height adjustment; you'll be set.
Donnie
Currently Porsche-less.....
Old 08-06-2005, 08:07 PM
