head studs
Anyone heard of the manufacturer of head studs called Canyon?
Slumlord
No, and I would not recommend you venture into unknown teritory with a Porsche and experimental head studs. Do some searching for on this site for ARP.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Still Doin Time
DITTO
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
MBruns for President
or raceware - or Supertech like I have...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Jeremy did I read right in one of your previous postst that the Supertec studs go in with BLUE loctite?
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Yep - that's what Henry provides - with the Supertech Head studs you have to bottom out the studs too - all the way to the bottom, then 1/2 turn.
Ahhh, that makes a little more semse then, I thought I was aging too fast! Got an overall first impression of those headstuds?? I am thinking of doing those or ARP but had originally planned on just using steel....
Jeff
Like works of art - beefy works of art - but works of art.
Grand Am/IMSA Data Guy
I'd suggest that you carefully measure the length of the stud after it is installed. I missed this on my first engine rebuild and the allen nuts are a problem if your studs are a bit too long. If the studs are too short, the nut does not get a full engagement. I believe the length was 130 mm. It is in some obsure place in Bruce Andersen's book. If the stud manfacturer is suggesting that you bottom them in the holes and turn 1/2 turn, you may end up with short studs. I like the red loctite, you can set the stud length where it should be and it is easy to remove with heat. Good luck.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Not critical with the supertech head studs
I believe by bottoming out the stud and giving it an extra half turn eliminates the need for the red loctite and lets you use the blue, I think. I am guessing they do not use a barrel nut as well..... Making height not quite as much of an issue. If I remember off the top of my head (ha) the stud length is 135mm.
Jeff
135mm - No barrel nut - 12 point nut instead.
Knew I had a picture somewhere...
Really? No one has heard of the Canyon studs? I have heard about them from two independent people. I will try to get more info...
-Brian |
Slumlord
Very Funny!!!! Do you use a metric wrench to torque the nuts?
Slumlord
Such a good joke, such an arcane topic. Story of my life.
Unregistered
Unless you are building a full race killer motor, the stock steel studs will do just fine (no dilivar, ever!).
If you are building a monster go with the really expensive stuff, it's a little better than stock. |
