jpc1818's Avatar
Porsche Crest head stud qurstion??????
I have the engine out. I'm replacing the clutch, and all the seals that I have access too, including the rocker shaft seals, which by the way were leaking like crazy. Anyway, I found one broken lower head stud. The engine is out but not totally apart. The engine was defiantly rebuilt, because of the engine sealing used all over the inside. too replace or not? That is the question?
Old 08-27-2005, 04:01 PM
Irrationally exuberant
ChrisBennet's Avatar
If you were one of my buddies here in the North East I'd tell him to run it easy this fall and rebuild it this winter. (We've got a month or two of driving weather before 6 months of winter.)
As you probably know, seeing sealant "all over the inside" is not the sign of a knowledgable rebuilder.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-28-2005, 04:16 AM
BReyes's Avatar
Sorry about the results of your inspection. You are looking at a top end rebuild. Not sure what you mean about the sealant on the inside, but I would want it to be correct once completed. Sounds like you have the skills to do some of the work. How many miles since the heads were reworked? You may want to have them dissassembled and the valves/guides checked out. PNC may be in spec.
Good luck.
Bernard
Old 08-28-2005, 10:02 AM
jpc1818's Avatar
I found only the one head studd. Since I have read its a frequent problem. So I put the engine back together and its running awesome. Thanks for the help and suggestions
1989 C4 Coupe
1975 911 carrera 2.7rs Sold
1978 911sc Sold
2001 Boxster S
Old 09-25-2005, 03:58 PM
