OK, when I had my engine rebuilt, I had my heads twin-plugged prep'd, however, I'm only running single plug for now, until I source a good used 964/993 Distributor.
Would I need to modify the 964/993 distributor to work on my Carrera motor, or would it be a simple swap out? I know I have to run a signal splitter off the OEM inition, twin Crane HI-6 Fireball ignition systems & twin Crane LX92 coils, but is there any machining required on the twin plug distributor to make it fit/work? Advice appreciated
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Merv:
Its a drop-in on Motronic motors with no modifications required.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Irrationally exuberant
You don't need to mod the distributor but I had to modify the heater ducting to make everything fit.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Warren Hall Student
Heater ducting, what's that?
cue Randy Newman: "I love L.A." "We love it!"
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
![]() -Chris
Thanks Steve & Chris
![]() Also, what's the going rate for a good used 964/993 dizzy these days? Anyone have one lying around?
Steve Timmons( IG) quoted me a price of 475.00 shipped, with a new belt. Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Merv you better make sure your turbo pipe will clear. I have a feeling you will have clearance issues here
Eric Hood |
The pre-IC charge air pipes will be re-done soon, after I install the new headers. I'll take all that into consideration
Gonna be pretty hard to make that clear especially with the larger pipe you will run with that "small turbo" I am sure it can be done though just wont work out of the box. For something to use on mock up you might try flexible dryer hose like material it works real nice for things like that
Eric Hood |
T70, a small Turbo?
![]() Agree tho! The 4" inlet to the compressor will be a huge mutha to route around that engine bay ![]() Thanks for the tip re:flex dryer hose.
Have you considered the Electromotive cranktrigger ignition system? I run that setup on my race car and it was easy to set up, has been trouble free, and is almost infinitely adjustable.
Joe 996 GT3 RSR |
Author of "101 Projects"
Bosch rebuilt is a little more than $700, and guaranteed to work like new:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911L§ion=elignt&page=3&bookmark=14&part_number=H-602-015-AX -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Grand Am/IMSA Data Guy
Merv
I twin plugged my 3.2 a few years ago. I got the 964 dist and replaced the belt. Thought I was good until I learned that I needed a "converter/igniter". The one I purchased was made by Andial and it cost $500 to $600. Think about that on top of the cost of the 964 distributor and it may be better to go crankfire as suggested above.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Try not, Do or Do not
ANOTHER OPTION:
TEST IS ON GOING BUT SO FAR SO GGOD AND WE'RE READY TO SHIP. ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
What is the price on those?
About $1200. They come with a new cap and rotor.
We can make them for most 911/ 930 applications.
We're waiting on a kit similar to that one that uses the Jaguar cap and a custom rotor...
-Wayne
3 restos WIP = psycho
When are the ones for early cars coming online?
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
