case studs
Hello,
During disassembly, a few studs came out with their respective nuts. For example, a stud for securing the oil sump plate and one from the timing chain housing came out. What is the proper practice for reinstalling these?
Thanks,
Brian
Old 11-29-2005, 11:15 PM
Friend of Warren
Not a big deal. Just clean the threaded holes out, use a bit of blue loctite and screw the studs back in.
Kurt V
Old 11-30-2005, 06:15 AM
Thanks!
-Brian
Old 11-30-2005, 08:46 AM
Irrationally exuberant
ChrisBennet's Avatar
I might add to what Kurt said: In the case of studs that "hang" down from something, let the Loctite set and then clean off (with a squirt of Brake Kleen) the loctite "nose drips" from the exposed stud before you put the nut on.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-30-2005, 11:46 AM
Good advice Chris. I will probably reinstall the studs in their various engine parts before assembly so they can dry right side up.
-Brian
Old 12-01-2005, 12:30 PM
does anyone know the part number for the sump plate studs?
81 911sc
05.5 new jetta
03 spectra
Old 12-30-2006, 06:07 PM
