case studs
Hello,
During disassembly, a few studs came out with their respective nuts. For example, a stud for securing the oil sump plate and one from the timing chain housing came out. What is the proper practice for reinstalling these? Thanks, Brian |
Friend of Warren
Not a big deal. Just clean the threaded holes out, use a bit of blue loctite and screw the studs back in.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks!
-Brian |
Irrationally exuberant
I might add to what Kurt said: In the case of studs that "hang" down from something, let the Loctite set and then clean off (with a squirt of Brake Kleen) the loctite "nose drips" from the exposed stud before you put the nut on.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Good advice Chris. I will probably reinstall the studs in their various engine parts before assembly so they can dry right side up.
-Brian |
does anyone know the part number for the sump plate studs?
81 911sc 05.5 new jetta 03 spectra |
