If that was of maximum concern, though I wouldn't think critical on a 350hp street car there are some coatings that enhance heat transfer. Sadly they are usually black but some will show real measurable numbers over other coatings or raw metals.
That same argument could be made against polishing as it decreases surface area. How about sandblasting the nice diecast surfaces with agressive media to increase surface area...it would be a bee-otch to keep clean. Ben, How about a pre and post dyno session with the different ignition systems? We could take up a pool since I'd like to see the benefits at this level in the real world. Has your current SC dizzy been recurved for boost or is it stock? If it wasn't optimized, I guess the ignition change comparison would be flawed.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Luke I may do that..
Here are pics as of today 1-30-07
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
Slumlord
That OSB has to go. Un-subscribed.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Looking good, Ben!!
Doug
1971 RSR - interpretation |
THANKS GUYS. I can't wait to finish this project up.. I hope the pictures are helpful to anyone thinking of doing this
abit off center
It’s too bad that most of what you see is hidden when its all back in the car, especially those heads
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Just got back from offshore.. & saw thread again...looking real nice Ben
Phil 2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift 1988 911 coupe (GP white) Turbocharged 1998 BMW 328i |
PM me your # again.. I have new cell phone & lost all my contacts
It really looks great, Ben. Consider buying a 600 lb lift table from pep boys or harbor freight - it really made my install a lot easier. Also, let us know when you need MS timing or fueling tables. Some of us who've gone before can get you idling and running more quickly than starting from scratch (right Hobieboy!). What size injectors are you using?
07 Audi A4 2.0T Cabriolet - Black/Black (sold) 96 993 C2 Cabriolet - Arena Red/Tan (sold) 82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold) 58 DKW Universal - Baby Crap Yellow/Beige (sold) |
I'm running 50# injectors. No problem with idle. Here's a link to my specs and MegaSquirt info.
Thanks for posting that, Mike.
Wildman Emeritus
Ben:
Looks very, very nice. Great progress and thanks for all the posts. I am so envious. I wish I had the money, time and technical skills to do this.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Here is as of this morning 2-1-07
Thanks for all the input and a big thanks to Henry@supertec for his advise along with Chris@moto-delta for his suggestions as well..
Brando
Very tight. Looks so nice! But that is not an easy "barb" method for the oil drain. I don't weld aluminium! I thought you had a easily duplicatable drain idea, like bolt on, hello!
Turbo powa! 1977 911s. it's cool |
I would suggest using hose clamps which won't cut into your oil return line, too. Aircraft or metric style seem to be less aggressive on the hoses. That said, maybe that beefy hose can take it.
Looks great!! Doug
Yeah the hose is 25 bucks a foot and capable of something like 500 PSi with a teflon lining so I was not to concerned about cutting in I want it to grip really well..
Oh and branden you could easily duplicate this with barb fittings and or an fittings I just chose stainless with some rubber connections.. I was hoping the hose to be black when I ordered it but hey now it looks like a garden hose
Green is cool! As long as it doesn't piss oil or water like a garden hose, no worries!!
McMaster has some nice SS aircraft grade hose clamps for pretty reasonable $. Although you probably have access to that in your backyard with the aircraft folks. Good luck! Looking like an engine! Are you going to fab an IC as part of this project, too? Doug
