Send a message via Yahoo to Lukesportsman
If that was of maximum concern, though I wouldn't think critical on a 350hp street car there are some coatings that enhance heat transfer. Sadly they are usually black but some will show real measurable numbers over other coatings or raw metals.
That same argument could be made against polishing as it decreases surface area. How about sandblasting the nice diecast surfaces with agressive media to increase surface area...it would be a bee-otch to keep clean.
Ben,
How about a pre and post dyno session with the different ignition systems? We could take up a pool since I'd like to see the benefits at this level in the real world. Has your current SC dizzy been recurved for boost or is it stock? If it wasn't optimized, I guess the ignition change comparison would be flawed.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 01-27-2007, 10:20 AM
Luke I may do that..
Here are pics as of today 1-30-07
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-30-2007, 05:32 AM
Slumlord
Porsche_monkey's Avatar
That OSB has to go. Un-subscribed.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-30-2007, 05:52 AM
DW SD's Avatar
Looking good, Ben!!
Doug
1971 RSR - interpretation
Old 01-30-2007, 08:08 AM
THANKS GUYS. I can't wait to finish this project up.. I hope the pictures are helpful to anyone thinking of doing this
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-30-2007, 10:54 AM
abit off center
cgarr's Avatar
It’s too bad that most of what you see is hidden when its all back in the car, especially those heads
______________________
Craig
G2Performance
Old 01-30-2007, 10:59 AM
yeah no kidding.. Now my biggest problem now is going to be trying to remove it from the engine stand..
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-31-2007, 05:25 AM
KCPSG's Avatar
Just got back from offshore.. & saw thread again...looking real nice Ben
Phil
2005 GT3 Milltek Exhaust/ECU reflashed/OEM Short shift
1988 911 coupe (GP white) Turbocharged
1998 BMW 328i
Old 01-31-2007, 05:29 AM
oh hey.. I found the right radius pipe for your AFM-TB.. Call me if you want one
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-31-2007, 05:30 AM
KCPSG's Avatar
PM me your # again.. I have new cell phone & lost all my contacts
Phil
1998 BMW 328i
Old 01-31-2007, 05:31 AM
mppickett's Avatar
It really looks great, Ben. Consider buying a 600 lb lift table from pep boys or harbor freight - it really made my install a lot easier. Also, let us know when you need MS timing or fueling tables. Some of us who've gone before can get you idling and running more quickly than starting from scratch (right Hobieboy!). What size injectors are you using?
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 01-31-2007, 06:53 AM
just 30# at the moment.. I will get it running off the dizzy and be using my VE tables from before I smoked the engine.. HobieBoy Is helping me with the ignition module for my MSI Version 2.2.. As soon as it is up and running I will dump the dizzy for the ignition set up and change the injectors and mess with that.. What injectors are you guys running??
Ben
89 944,85.5 944
914-6werkshop.com
Old 01-31-2007, 07:32 AM
mppickett's Avatar
I'm running 50# injectors. No problem with idle. Here's a link to my specs and MegaSquirt info.
Old 01-31-2007, 01:57 PM
Thanks for posting that, Mike.
Luke S.
Old 01-31-2007, 03:37 PM
Wildman Emeritus
Ben:
Looks very, very nice. Great progress and thanks for all the posts.
I am so envious. I wish I had the money, time and technical skills to do this.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 02-01-2007, 05:16 AM
Here is as of this morning 2-1-07
Thanks for all the input and a big thanks to Henry@supertec for his advise along with Chris@moto-delta for his suggestions as well..
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-01-2007, 05:25 AM
Brando
quattrorunner's Avatar
Very tight. Looks so nice! But that is not an easy "barb" method for the oil drain. I don't weld aluminium! I thought you had a easily duplicatable drain idea, like bolt on, hello!
Turbo powa!
1977 911s. it's cool
Old 02-01-2007, 08:20 AM
DW SD's Avatar
I would suggest using hose clamps which won't cut into your oil return line, too. Aircraft or metric style seem to be less aggressive on the hoses. That said, maybe that beefy hose can take it.
Looks great!!
Doug
Old 02-01-2007, 08:54 AM
Yeah the hose is 25 bucks a foot and capable of something like 500 PSi with a teflon lining so I was not to concerned about cutting in I want it to grip really well..
Oh and branden you could easily duplicate this with barb fittings and or an fittings I just chose stainless with some rubber connections.. I was hoping the hose to be black when I ordered it but hey now it looks like a garden hose
Ben
89 944,85.5 944
914-6werkshop.com
Old 02-01-2007, 08:58 AM
DW SD's Avatar
Green is cool! As long as it doesn't piss oil or water like a garden hose, no worries!!
McMaster has some nice SS aircraft grade hose clamps for pretty reasonable $. Although you probably have access to that in your backyard with the aircraft folks.
Good luck! Looking like an engine! Are you going to fab an IC as part of this project, too?
Doug
Old 02-01-2007, 09:02 AM
