Jeff Alton's Avatar
3.4 build part 2!
23 months ago was the last time I heard my car running. In feb of last year I started this thread 3.4 has begun! (part 1)
about taking the motor apart. The plan was to have it back on the track in 1 year......
So, today, it so happens that the head tuner from Microtech (the ecu I purchased) was in town, from Australia, helping my tuner with some programming. They invited me down and Jon confirmed my suspiscions about an error in the wiring diagram for the injectors.
Came home tonight and moved the connectors to the appropriate injectors. I had left the harness long in anticipation of the diagram being incorrect.
So, here is how my night went......
Turn on key.
Run motor over on starter button until oil pressure builds.
Confirm basic (very basic) timing with a timing light while motor is cranking to build pressure.
Jump in the seat.
Turn on ECU switch.
Turn on fuel pump switch.
Have a sip of Mission Hill Occulus (very tasty, been saving it)
Take a deep breath.
Think in "fast forward" about all the things that could go wrong.
Push starter button.
She fires right up with a little pressure on the pedal!!
Nearly soil myself, take deep breathes to slow heart rate down.
Turn motor off quickly.
The motor only has an very basic initial tune from Microtech in it. But it fired. It will now go on a flat deck down to the tuners. (Nice and close to here) where it will be broken in on the dyno and then give a max power tune. We will be tuning it for 100 octane, 94 octane adn 91 octane. I can get 94 at the pumps here, 100+ at some of the tracks I go to and 91 if I travel in the NW USA with it. The computor will store 4 different programs in it.
I will document with pictures and hopefully video the tunning process. I will also be calling on the expertise of two very well known contributors to this, and many other, forums to help me with the text to go along with the process.
I want to be able to show what worked for ME, and what did not. Show what the tunning process is like.
Here are the specs again....
3.4L based on a 3.2 (case, crank, rods, and heads)
10.5:1 compression (measured)
Balanced rods and pistons.
Twin plugged.
Microtech ECU and ignition box.
6 dual tower MSD coils
DC44 cams on 108 lobe centers
Race valve spring and Ti retainers
Jenvey 48mm ITB's with blended manifolds and custom linkage.
B&B 1 5/8 headers with heat.
M&K GT3 style twin center outlet muffler.
Big Setrab front mount oil cooler.
Man, I really want to go fire it again, but I made a commitment to break it in on the dyno. Unfortuanetly, I don't think that will happen for another 8 days......
Here is a pic of the motor....
Okay, here is another of it in the car!
Cheers
www.turn3autosport.com
Old 08-09-2007, 08:38 PM
3 restos WIP = psycho
kenikh's Avatar
CONGRATS!!!
I can't wait to see what kind of power the DC44s make. I am building a 2.3 w/ DC44s on 102 lobe centers and can't wait for a seat of the pants assessment of the character.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-09-2007, 09:13 PM
89turbocabmike's Avatar
Nice Jeff, she looks beautiful.
ITB's of course look sweet, but I really like the lack of SS lines and the silver/black valve cover look.
Start up's never fail to get the blood pumping, it's one of my favorite adrenaline rushes. You have much better self control than I do...I would have cruised it a little round the block
Jeff Alton's Avatar
Hmmh, I have wheels (just picked them up today) but tires are not mounted. Windsheild is not in.... tail lights not installed... I think I am just going to have to pretend for a while on the dyno....
Thanks for the compliments. I tried to keep it as low key looking as possible. Painted the shroud body color and the exposed aluminum bits are bead blasted or poweder coated satin black. No funky color fan and housing. Black igintion wires blah blah blah blah......
I have build quite a few engines in the past, but always with the existing fuel and ignition system. This was a very healthy modded 3.2 that I took a part. I was very very very nervous about firing it with a completely different ECU, intake system, and ignition system. Very frightened in fact.
For the few seconds it ran it was lumpy. There is a ton of work to go here still. Need to balance the 6 throttles, tune the fuel maps, tune the ignition maps, break the motor in................
I am actually looking forward to long days with the ear plugs in at the dyno shop! If it doesn't make 255 at the wheels there may be and accident.....
Cheers
Old 08-09-2007, 10:35 PM
kenikh's Avatar
What's your redline? Those cams will make almost 100HP/L at 8000 RPM. Those revs are a unattainable for 98mm pistons on 74.4mm crank, but curious nonetheless.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-09-2007, 10:38 PM
Jeff Alton's Avatar
Well, the bottom end is balanced and has ARP rod bolts.... But, I chose this cam specifically off the recomendation of John. I have only 1 5/8 headers and he thought with the 48mm throttle, 10.50 CR and that exhaust that this was a good choice. If I remember correctly, he thought the motor should make peak power around 7200-7500rpm.
We will see...
The goals of this motor were a fairly wide powerband, and snappy throttle response. I also wanted to be able to pull into the low to mid 7K rpms. John had said that similar 3.4's were making well above 300hp at the flywheel with this cam and 46mm PMO's.
The outright HP number is not important to me. I will know when I drive it if it met my goals. Car will be 2400lbs +/- a few so it should scoot. I am a throttle response junkie so I am hoping it meets those needs.
Cheers
Old 08-09-2007, 10:49 PM
alpina's Avatar
Cant wait to hear what she puts down to the ground...
Chuck
99" 996 C2, 04" Mini Cooper, 66" sprite (scca "DP" sold)
87" M5 (sold), 73" 914 2.2 (sold), 72" 914 1.7 (sold)
79" Alpina B6 (sold)
Old 08-10-2007, 12:42 AM
MBruns for President
JeremyD's Avatar
Jeff - I would be suprised if you were not in the 270-280+ rwhp. That engine is a work of art.
Old 08-10-2007, 07:04 AM
TheMentat's Avatar
sweet Jeff... congrats!
Silver '88 RoW Carrera
Grey '06 A4 Avant
Old 08-10-2007, 07:34 AM
I would rather be driving
jpnovak's Avatar
Jeff, that is great news. I was also very excited when my EFI started for the first time.
I just wish I had the funds to tune on a dyno. I have been tuning on the street and its really running well now. the datalog files are your best friend.
Just watch out for the off-idle response. I find that with 46mm ITBs they dump a lot of air with very little change in rpm. The engine wants to go quickly lean when you crack the throttle. This means it will be crucial to get your base VE map and acceleration parameters correct. I had a lot of problems with the engine stalling until I figured this out on my own. Nothing like seeing the AFR spike above 18 when opening the throttle. I am sure you are in great hands with your tuners.
Best of luck. I can't wait to see the dyno charts. I think you will be above 300 if you are spinning above 7K.
Old 08-10-2007, 10:26 AM
Congrats Jeff !!!
Keep us posted on the tuning progress & can't wait to see your final results
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 08-10-2007, 11:45 AM
camgrinder's Avatar
Looks great Jeff. I cant wait to see the numbers.
John Dougherty
Dougherty Racing Cams
Old 08-10-2007, 12:49 PM
boba's Avatar
Congratulations Jeff, looks fantastic.
I know how hard it must be to not go out to the car and fire it up just to hear it run.
Looking forward to your updates as you get it set up on the dyno and then on the road.
Regards,
Bob
Old 08-10-2007, 02:44 PM
KTL KTL is online now
Schleprock
KTL's Avatar
SCHWING!!!!
Nicely done. Hope it rips asphalt like a......well.......... like a flat six should with those kinda credentials!!!!
Kevin L
'86 Carrera "Larry"
Old 08-10-2007, 03:02 PM
Irrationally exuberant
ChrisBennet's Avatar
Very exciting!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-11-2007, 03:57 AM
user & abuser
Talking
255 is very conservative!!!
i'm sue you'll meet that goal and then some, but like you said, #'s are not the purpose, it fun in the hot seat that counts, and thats what high(er) compression N/A is all about!!!!
cannot wait to see you results!
we should start the intial 'betting' as to what the dyno results will be...
i'll say first full run something like 260hp, after 'long days with ear muffs on' i'll bet 285ish, if you can get it to peak between 70-7200rpm, for mainly a street driven car i can't see you actually wanting to wind it up past there...
this is coming for a 20yr old kid, who has a similar (minus the fancy ITB fuel injection) setup, which was intially set to wind to 7200rpm, but has been pulled down to 7000,
ps, the B&B's + M&K sound best right aound 55-6000rpm's, 6-7 happens so fast you cannot eally remember if you heard anything :P
vini vidi vici
Old 08-11-2007, 11:05 AM
What kind of dyno is your tuner using Jeff? I'm hoping a dyno-dynamics or dyna-pack
Old 08-11-2007, 11:49 AM
Jeff Alton's Avatar
He has a dynojet, and there is a mustang and another dynodynamics all with in 5 miles. Once it is done, I am going to do a little test to see how the different dyno's/operators compare with each other....
Cheers
Old 08-11-2007, 01:57 PM
Jeff Alton's Avatar
Well, tonight I did a little adjustment on the timing and and did my best to set the static postition of the ITBs and then fired it up again!!
Ran it for about 1 mins. (last time before the dyno, I promise! ) Lots of oil pressure!! It certainly needs some proffesional help for the tunning..... it farts and sputters a wee bit below 1500 rpm.
It has unbelievable throttle response, like nothing I have ever felt. That is the most welcome news for me, as that is the number one reason I built this thing. Just touch the throttle and it is like lightning! Totally blows my mind.
Oh, it is really really really loud........ I had my garage door open (town house complex) and in about 30 sec I had 6 spectators........ Ooops! Oh well, at least my dogs don't bark!
Cheers
Old 08-11-2007, 07:53 PM
subscribed to see what the outcome is #s wise
Old 08-11-2007, 08:26 PM
