Air Medal or two
afterburn 549's Avatar
Did anyone mention turbo and a aluminum case ? there many pouting out that hp...don't know if that will fit your application
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 08-21-2007, 01:11 PM
3 restos WIP = psycho
kenikh's Avatar
Originally Posted by HawgRyder View Post
And here I am rebuilding my 2.0L "S" with perhaps 90mm barrels, using an aluminum case and very large oil pump (got it off Ebay about 4 yrs ago).
The original idea was to build something with less compression so I could use lower octane gas.
I have been told, if I just use the 90mm barrels, without decking the cylinders or the heads, I will drop about 1 1/2 points on the C/R.
I have looked at the sets of 90mm barrels, and I notice that they have a groove at the top for a sealing ring?? perhaps.
Henry..can I use my S heads on these barrels...or am I now looking for heads as well?
Bob
Bob, tell me you aren't drilling a real 'S' case for 90mm P/Cs. I realize that we build these cars for ourselves, but doing the un-undoable on a rare and valuable case should give you pause.
FWIW, you will have to machine the sealing surface of your 'S' heads to get them to mate properly to 90mm cylinders which were designed for the later (flatter) head plus chamfer the inner edge of the combustion chamber for the larger pistons. It just leads to more undoable hackery of rare and valuable parts.
Do what I am doing: build a new motor from less rare parts.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-21-2007, 04:03 PM
kenikh's Avatar
If your ally case is not an 'S' case, have at it! My comments on hacking the heads stand though. I used a set of '69S heads that were chamfered in the '80s to build my latest motor. They were functionally useless since no one wanted them anymore (and the fact they now required custom pistons). If your heads are already monkeyed with, then there is no guilt in doing this.
BTW, I have a very nice set of twin plug, ported, later heads and 90mm P/Cs with 10.5:1 CR pistons (on a 70.4mm crank). The CR would be about 9:1 on a 66mm crank for a 2.5 short stroke motor. They will be posted for sale here in the upcoming weeks (after I clean them).
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-21-2007, 04:11 PM
Skunk works
JV911SYDNEY's Avatar
Originally Posted by Henry Schmidt View Post
Pictures? You want pictures? You can't handle these pictures!
oops, channelling Jack again
I just got a woodie
964 RS-4
Old 08-23-2007, 09:06 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Woodie nothing - I think I need a kleenex. . .
I'd love to do a 3.6L conversion, but I suspect it'd be about 15-20 grand by the time all was said and done. . .
Maybe when I find that elusive winning lottery ticket.
Black Cars Matter
Old 09-07-2007, 11:40 AM
kenikh's Avatar
One more thought on a 300HP 2.7 w/o using an early turbo case. You could use an early aluminum case, 66mm crank, have some custom Nickies made with thin skirts, bore your case accordingly and use custom 92.5 mm JEs...voila, 2.7SS. You would then have the displacement and short stroke to get the revs up for 300HP (with RSR cams).
Expect at least one child to miss out on college for building this motor.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-07-2007, 03:23 PM
