LinkBack | Thread Tools | Rate Thread |
Air Medal or two
Did anyone mention turbo and a aluminum case ? there many pouting out that hp...don't know if that will fit your application
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
3 restos WIP = psycho
FWIW, you will have to machine the sealing surface of your 'S' heads to get them to mate properly to 90mm cylinders which were designed for the later (flatter) head plus chamfer the inner edge of the combustion chamber for the larger pistons. It just leads to more undoable hackery of rare and valuable parts. Do what I am doing: build a new motor from less rare parts.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 08-21-2007 at 04:06 PM.. |
If your ally case is not an 'S' case, have at it!
My comments on hacking the heads stand though. I used a set of '69S heads that were chamfered in the '80s to build my latest motor. They were functionally useless since no one wanted them anymore (and the fact they now required custom pistons). If your heads are already monkeyed with, then there is no guilt in doing this.BTW, I have a very nice set of twin plug, ported, later heads and 90mm P/Cs with 10.5:1 CR pistons (on a 70.4mm crank). The CR would be about 9:1 on a 66mm crank for a 2.5 short stroke motor. They will be posted for sale here in the upcoming weeks (after I clean them).
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Skunk works
![]() I just got a woodie
964 RS-4 Last edited by JV911SYDNEY; 08-27-2007 at 06:10 PM.. |
Dog-faced pony soldier
Woodie nothing - I think I need a kleenex. . .
I'd love to do a 3.6L conversion, but I suspect it'd be about 15-20 grand by the time all was said and done. . . Maybe when I find that elusive winning lottery ticket.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
One more thought on a 300HP 2.7 w/o using an early turbo case. You could use an early aluminum case, 66mm crank, have some custom Nickies made with thin skirts, bore your case accordingly and use custom 92.5 mm JEs...voila, 2.7SS. You would then have the displacement and short stroke to get the revs up for 300HP (with RSR cams).
Expect at least one child to miss out on college for building this motor.
