Free minder
Allright, that hose connects to a hidden nipple on the cruise control servo. Got the answer on the big technical forum.
Aurel |
Free minder
John (oldTEE)
I tried to fire it up, but I get no fuel at the injectors. I tried to prime the system, and no luck. Can you give me more details on the procedure? You disconnect the WUR, lift the air sensor plate and crank the motor? For how long? Damn, I hope that old CIS is not going to let me down... Aurel Last edited by Aurel; 05-04-2008 at 02:52 PM.. |
Careful here you could fill a cyl with fuel and lock up the engine. Break the fuel line from the fuel distributor to the WRU. 14mm I think. Then turn on the ignition, then lift the sensor plate. You will hear the fuel pump go. When fuel comes from the line you removed, replace it. The system should now be primed and should fire, all things equal, after a couple of rurrrrs, rurrrs.
Otherwise something else is amiss. To run you need fuel, fire and air. Check for spark. Leave the air filter off for the moment.
Old Tee all 911s sold |
Sounds like you have good oil pressure with 1 bar during cranking.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Free minder
OK I`ll try again. When you say turn on the ignition, you mean without cranking, right?
Aurel |
No cranking needed, the fuel pump will do the work.
You don't crank the engine to pressurize the fuel system. Check for leaks. Let us know when it fires.
Free minder
So, when I tried to disconnect the fuel line to the WUR , fuel came out of it, so it seems primed. But, when I disconnect an injector and place it in a jar then crank, there is no fuel coming out of it(I tried two injectors). Also, when I lift the sensor plate, I really don`t hear anything going on???
Aurel |
Free minder
And yes, I put the fuel relay back in.
Aurel |
Cranking does nothing. If you raise the sensor plate you should hear the fuel pump. (Ignition on, relay in, fuel in tank (don't laugh, it happend to me once)). You might crack the fuel line (the one right above and behind #3 cylinder. The puel pump puts out about 80lbs so you should get a spry. One second should do it. Maybe a blockage somewhere. Check your fuses. |
Free minder
I do not hear the fuel pump at all, so maybe an electrical issue. Where is the fuel pump, BTW? Are there two, one in the front and one in the back? I am going to have to look into that...unfortunately, the car is not going to run tonight. At least I had good oil pressure, and that motor sure looks better than before
.Aurel ![]() Aurel |
I don't think the fuel pump is supposed to run unless the engine is running. If your fuel pump runs with the ignition key turned, something is wrong.
You can jump the fuel pump relay and turn the ignition key on in order to get the fuel pump running without the engine running. This is how you would perform fuel pressure tests. Let me know if you need further help with this. See page 240-11 in the Bentley.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
Retired Member
With the key on, you should hear the CDI box humming. Do you get spark at one of the plugs?
You mention no gas at the injectors. With the ignition key in the on position and the air filter out, reach in and gently lift the flapper valve. You will then hear the gas pump start (it is located under the car near the steering rack - covered by a skid plate). You should then see gas coming out of the injectors. Note - with CIS all injectors will constantly spray gas when the pump is running. Therefore, do not do this too much because the gas goes right into the cylinders when each intake opens. I would start with this.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Free minder
Charlie,
The CDI box is humming. I haven`t checked for spark yet, but since I get no fuel to the injectors, first things first. I did lift the flapper valve, and heard nothing. Aurel |
Retired Member
Run a jumper wire at the fuel pump relay socket. This will bypass the controls within the engine compartment. You will hear the pump when you turn the ignition key on.
The Bently manual details this procedure. Cheers.
Free minder
Aurel |
Retired Member
black relay will work - not sure of the difference.
Red and black are not the same, red have a "quench" diode across the contacts to prevent back EMF. As such you don't want to back-wind the diode.
More Obscure Electrical Brain Teasers
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Free minder
I bridged terminals #30 and 87 on the fuel pump relay socket with the ignition on, and I heard nuthin...all points out to a faulty fuel pump. Maybe just seized? I also think the relay is fine, because I heard it click when I plugged it back. Now, gotta dig that fuel pump out.
Aurel |
Retired Member
Crap - deeper issue.
When you access the pump, disconnect the wiring and apply 12 volts to it to as a last check before pulling it out. If you replace, I would suggest to also get a new check valve - it attaches to the pump. One of those "while you are there" items. When I replaced my fuel pump, I took it to the local euro parts store and matched the Bosch part number on the pump. It was the same as a mid 1970's VW Rabbit at 1/2 price for the Porsche pump.
