dtw dtw is offline
GAFB
Craig - I'd like to ask what your procedure is for checking clearance on the main bearings. I'm about to do the same and am trying to figure out how to do it without smearing the plastigauge while I'm torquing up the case.
BTW, your rockers are on the way.
Several BMWs
Old 02-26-2008, 09:11 AM
dweymer's Avatar
ain't that the point of the plasitgauge?
Donnie
Currently Porsche-less.....
Old 02-26-2008, 09:12 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Paul...I had forgotten the Sunnen...thanks.
Also...might it be possible to mill the intermediate shaft surfaces?
I was just looking at a spare case I have....and it's not that deep into the case when the case is stood up on the flywheel end.
Might be worth a try with a long reach tool.
Bob
Bob Hutson
Old 02-26-2008, 09:13 AM
abit off center
cgarr's Avatar
The area that was .001 off was at the breather flange, with only the mains bolted up I could just get a feeler gauge in there. I used 4 reference points on the mating surfaces where they were checked with a mic to indicate that only .004 was removed. (Dave) The plasitgauge stays in place pretty good, you can use a dab of oil to help hold it and you do not want to turn anything (crank) and gently bolt the halves together, this will squish the gauge and give you a reading of the bearing clearance once the case is separated. The case project is on hold awaiting money for rods, bearings, chains etc.
______________________
Craig
G2Performance
Old 02-26-2008, 09:45 AM
dtw dtw is offline
GAFB
Can you carefully turn the case from horizontal to upright to torque down the through-bolts, Craig?
Donnie - with plastigauge, it is often tricky keeping the parts you are measuring from turning, which smears the wax and causes an inaccurate reading. Rods for example, are very difficult to keep perfectly still while you torque down the rod bolts. At least for rookies like me it can be pretty time consuming. I'm going to be doing all the clearancing work before the actual build clinic on the 15th.
Several BMWs
Old 02-26-2008, 10:11 AM
dweymer's Avatar
Dave, got it; was unsure of the smear part.
Thanks Craig
Donnie
Old 02-26-2008, 10:17 AM
abit off center
cgarr's Avatar
Yes, once you get it snug you can turn it upright to torque it. It would be very hard to turn the crank with the gauge in place on all the bearings.
Craig
G2Performance
Old 02-26-2008, 10:24 AM
abit off center
cgarr's Avatar
A little update: I wanted to make a test bar for the finished case rather than checking it with a new set of bearings, This is what I came up with: Turned and ground a bar to 62mm 20" long to fit the case, this will also be useful for the jig when installing the additional alignment sleeves on each main bearing web:
Craig
G2Performance
Old 02-08-2009, 08:12 AM
Carrerax's Avatar
Great job!! Im enjoying the read. Did you ever say what you used to clean the case so well?
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 02-10-2009, 05:23 PM
Navin Johnson
TimT's Avatar
Senor Craig.. this post reminded me of the pm I sent a few days ago..
check yer mail...
'69 911 GT-5
'75 914 GT-3
and others
Old 02-10-2009, 05:47 PM
KTL KTL is offline
Schleprock
KTL's Avatar
That's outstanding!
What's that checking bar weigh?
Kevin L
'86 Carrera "Larry"
Old 11-03-2011, 02:35 PM
abit off center
cgarr's Avatar
Originally Posted by KTL View Post
That's outstanding!
You made me dig thru the basement to find that thing! 508x62mm 26lbs
Craig
G2Performance
Old 11-03-2011, 05:15 PM
304065's Avatar
Craig,
That huge checking bar presents a great opportunity to gather a piece of data that we don't have.
What is the distance between the spigot height and the bar? You could measure with a depth mic. Or with a simple caliper cross a straightedge placed across the spigot.
The 356 guys have this spec, I know we use it when cases are resurfaced, but I've never seen it in print. This will help establish the distance between crank centerline (half the diameter of the bar) and the spigot height, which together with cylinder height will help us understand the geometry for deck height. Not that we can't set it now, I just have never seen the spigot height number published.
I realize you may have to dig out the bar again. . . counts as excercise. . .
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-04-2011, 05:02 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Only 26 lbs? I thought it would be heavier. The crank is heavier than that.
Kevin L
'86 Carrera "Larry"
Old 11-04-2011, 09:17 AM
denniger's Avatar
Looks great Craig. I'm doing all this now. Very entertaining! I'm concerned about the distributor drive.. one can potentially remove all the play in the distributor drive/ crank gear. Did you experience any problems?
Old 06-01-2019, 05:42 PM
Hey Denniger, don't expect too quick a reply on ypur post. In case you didn't notice, the thread was started way back in 2007 and the last post was over 7-1/2 years ago. Still very interesting, though...
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 06-01-2019, 09:38 PM
I jnow, I've been waiting all thiese years to find out what he uses to get his cases so clean
Tony
Old 06-06-2019, 10:45 AM
