Porsche's Love-em Live-em
You have a virgin case. Nothing appears to have been done to the head studs threads in the case. If you have no pulled studs you are starting with the best case scenario! Again I recommend 2nd oversize case savers if you can get them. ist over size will probably last for very long time as well if only option. Aloha
For comparison purposes, I just took a pic of my 7R case without the studs. I believe this is a virgin case too, but it does have the appearance of some kind of insert. Why would it look like this if the threads are machined into the case?
Dion
Dion 2002 Boxster S 1999 M3 |
GAFB
Agreed, that's a virgin case. Did you already start removing studs? A couple of the studs pictured are not threaded deep enough to be at 135mm.
A pic of a well-cleaned surface would really help clear this up.
Several BMWs |
abit off center
If you can get one stud out, stick a magnet down there and check the threads.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
D
Is this trouble, or not????
GAFB
What? You talking about the texture of the casting? No, no trouble.
Several BMWs |
Fuggit... split the case
When in doubt... SPLIT IT!!! Got pissed off over all the agony, and said to hell with it. Glad I did.
![]() Looks like the main bearings have some discoloration or pitting from sitting up for several years, as well as a bit of scoring.... ![]() and now, the $25,000 question... are these standard, or oversize? If they're standard, I think I'll go ahead with the rebuild. If they're oversize, I've heard they're ungodly expensive, and I may part it out and go back to a stroker type 4.
GAFB
That bearing actually looks pretty good, all things considered.
I can't find that part number - can you put a caliper on the bearing and give a measurement of the thickness?
Several BMWs |
Bearings measure 2.46 - 2.50 mm. or .096-.097" What do you think?
the "00" at the end means -----> STD/STD
Have the case checked carefully for bore, etc. My webs had areas where there was obvious movement. I'm having only two shuffle pins placed in the middle. Good pictures - I'm doing a similar rebuild using two engines and EBay. The magnet test for headstud inserts is what my machinist used to quickly answer that question.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016 <ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07 Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted. 2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon Last edited by notmytarga; 05-12-2008 at 12:15 PM.. Reason: More to say |
GAFB
Also, the factory 'symbol' stamped on the bearing suggests this is the original set of bearings. Are you up to speed on the care and feeding of mag 911 engine cases? You'll need to take (or ship) the case to someone who is very familiar with the measuring/qualifying and servicing of these cases.
Several BMWs |
Yep, it's being boxed up with the heads and shipped to CGarr for measurement/machine work.
Disassembly is complete!!!! Now, since I don't want to send Craig a filthy case to work on, how is the best way to clean the empty case? I've heard so many horror stories about media blasting clogging the oil passages that I know better than to do that. Can I just submerge the whole side of the case in a pan of Diesel and go to town with a brush? I just want to make sure that I don't do anything to potentially clog or get grit into my oil passages that I later can't get out. As always, your thoughts are appreciated!!! ONWARD TO REASSEMBLY!!
Max Sluiter
Check out this thread Media Blasting Heads?....Input Needed
Looks like an ultrasonic cleaning cabinet with water, mild detergent, and some citrus cleaner is a good way to clean parts without damage. Soda blasting seems to be more of a fine cleaning than other media like sand.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Well.... good news today from the machine shop. I just got back from having my cylinders measured, and they all have less than .001" taper (most were around 0.0005"). So it looks like they're good candidates for the scotchbrite/re-ring treatment. I still need to measure the top ring gap to make sure they're within spec, but most everything else has had almost no wear. I was asking the machinist about parts cleaning--like if they had a soda blaster--and he recommended a high pressure parts washer that they have. I asked if it was safe for aluminum/magnesium, and he said it was completely non-caustic. Anyone have experiences--good or bad? The box with the case and heads is on the porch waiting for FedEx pickup. The goals for the week are to get the cams/lifters out to John Dougherty for inspection and regrinding. Also, I hope to get the rods off the crank, and have the crank polished and measured. I'm going to let the local machinist measure the rods as well..... More later!
OK Gang,
Here is a pic of one of my main journals--do I really need to strip the crank and have it micropolished? I set the crank up on the flywheel to start stripping it down. Here again, I find myself asking... is this really necessary? From your comments, the main bearings had negligible wear. When I spin the rods on the crank, they are literally buttery smooth. No wiggle, no slop. I'm beginning to wonder how many miles this motor had on it since the rebuild. Your thoughts are always welcome....
Hi All,
Well, things are finally picking up steam again toward reconstruction. I am at the stage where I need to have the rotating assembly balanced prior to sealing up the short block. Here are my questions.... I'm using an early 911 flywheel. How many alignment pins are there supposed to be on the flywheel. The pressure plate and the flywheel have holes for three pins, but I have only two. You can see the two pins at approximately 5 and 9 o'clock in the photo. Maybe the machine shop lost one when they pulled them out to surface the flywheel??? See pic. ![]() Second, do I need to install the "ring" from the later model flywheel under the bolts? There is a depression for this "ring" under the bolts on the 2.7 flywheel. There is no such depression on the early flywheel. Do I need washers under the bolts? ![]() Last, what type of bolts do I need to use to secure the pressure plate to the flywheel? Will standard grade 8 steel work? Thanks tons, guys!!! --jaybird |
We're underway again!!! I picked up my freshly balanced rotating assembly last friday. At last, all the machine work is done. I finally got to pull the trigger on the rebuild kit that had been sitting in my pelican parts shopping cart for six months. I told myself that I wouldn't order anything for the rebuild until it was time for reassembly. Blew the whole wad this morning--to the tune of $1500 in parts. I'll try to post some pics of the reassembly once I get underway late next week. See you all soon!!
I would rather be driving
Nice Jay, where did you get the balancing done? Was it local?
I guess I need to speed up my assembly. I still have a transmission to complete after the motor is done.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
