blau911's Avatar
What should compression test numbers be like for a 2.4T motor?
I am considering buying a 2.4T motor and was curious to know what is a good compression number for a stock 2.4 911T motor.
Compression numbers I am getting are between 108 and 120. Doesn't that seem low?
Old 09-19-2008, 07:24 AM
Make sure the compression check is done with a wide open throttle. If not, the compression readings will all be low.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 09-19-2008, 10:04 AM
My 2.4t gives about 135 psi
'72 911T
'73 MGB (sold)
'71 Alfa GTV (sold)
Old 09-19-2008, 04:12 PM
blau911's Avatar
Guys,
Here are the compression and leakdown test numbers for the motor I am thinking of buying. As you can see, the compression numbers vary widely spread out between 125-146. The leakdown number on #4 cylinder is high at 15%. Do these numbers indicate that the motor is in need of a rebuild?
Compression / leakdown
#1 125 / 3%
#2 128 / 4%
#3 132 / 6%
#4 146 / 15%
#5 142 / 9%
#6 137 / 4%.
Any thoughts and or advice would be appreciated.
Old 09-28-2008, 12:23 AM
I've seen a lot worse on strong motors.
1972 911T/S MFI Survivor
Old 10-02-2008, 08:58 AM
Was the leak test performed on a hot engine? Makes a difference. Where was the leakage for the low cylinder (no. 4)?
Compression numbers and Leak down results aren't consistent with each other.
Tell us more.
Sherwood
Old 10-02-2008, 01:47 PM
