LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Forced Induction Junkie
WERK I's Avatar
Sorry. If you look on the web page, the password is next to "PASS"........it's "wiringdiagrams21.com"....no quotes. good luck.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-29-2008, 12:05 PM
Jeff Alton's Avatar
I am a little confused...
Are you trying to fire more than one coil at a time with same ground trigger wire from the ignitor/controller?
Cheers
www.turn3autosport.com
Old 10-29-2008, 04:17 PM
Wer bremst verliert
JohnJL's Avatar
Its a 48MB file so no postie here. Its 125 pages of delight. Lots of detail there, I'll have to take a look later at the ignition sections...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-30-2008, 01:49 AM
sjf911's Avatar
This COP solution is incredible. How well do the lower plug coils handle the exhaust heat? Please post some pictures of your setup and 3 coil controller.
I assume that you are actually producing a "pseudo-wasted spark" ignition with this scheme, is that correct?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 11-12-2008, 03:13 PM
3 restos WIP = psycho
kenikh's Avatar
Yes, pics tell a thousand words and I am reaaaally interested in doing this for my car.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-12-2008, 04:59 PM
kenikh's Avatar
Originally Posted by gestalt1 View Post
i guess any multi-coil type ignition controller, including efi controllers with ignition control could run these coils - right? Great find with the kawasaki coils! this could possibly be the cheapest way to get a twin plug system i've seen yet. $50-100 for coils, approx $200 for a salvaged controller, $200 for trigger wheel/sensor and $500 for head machining = $1000
Subtract $175 for the controller wheel...you can graft a cheap toothed wheel onto your existing crank wheel for about $25. Subtract the $500 for head machining, since that is assumed. Twin plug for under $400. Compelling? YOU BET YOUR SWEET A$$!!!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-12-2008, 05:06 PM
Jeff Alton's Avatar
I still want to see the setup and wiring for a vehicle running 12 plugs and only 3 ignitors....
Cheers
Old 11-12-2008, 06:58 PM
WERK I's Avatar
Cheers
+1
I can see two modified HPV-1 modules required for something like this.
Dave
Old 11-12-2008, 07:05 PM
Wer bremst verliert
JohnJL's Avatar
I run 2. Not sure how 3 works?
Old 11-13-2008, 01:23 AM
safe's Avatar
I would be a lot more interested in how you can fire a six cylinder engine with 2 ignitors...
Magnus
Old 11-13-2008, 01:49 AM
Navin Johnson
TimT's Avatar
You use one three channel ignitor for 6 plug waste spark, two three channel for dual plug waste spark.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-13-2008, 10:32 AM
Actually, "waste spark" is a misnomer in this case. A true "waste spark" system uses one double ended coil for 2 cylinders, and a common high voltage circuit for 2 spark plugs. If you could, without shocking the bejeezus out of yourself, pull one plug wire, you would kill two cylinders. What makes it work is that the inert exhaust gases in the non power producing cylinder have very little resistance to a spark jumping the plug, so the voltage goes to the cylinder on the compression stroke.
This system uses a pseudo-waste spark system. It triggers 2 separate coils, one on the exhaust stroke of a cylinder, and one on the compression stroke of a different cylinder. More efficiency can be gained by using a true sequential ignition system.
Don't get me wrong, this is a very ingenious way to setup your ignition, and I am sure it works great. I am taking note of this for my project.
But for the cool look factor, I am probably going with an old school RSR Style twin plug distributor.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 11-13-2008, 12:37 PM
sjf911's Avatar
Actually, it looks like it triggers 4 coils simultaneously, 2 on the compression stroke and 2 on the exhaust stroke like wasted spark which would use only 2 coils for the same number of spark plugs.
Sapere aude
Old 11-13-2008, 08:19 PM
Wer bremst verliert
JohnJL's Avatar
Mine is Accell 6-tower coils (same as EDIS-6) with a pair of triple-channel Haltech ignitors. I have burned through 2 Haltechs.
Old 11-14-2008, 12:26 PM
kenikh's Avatar
So correct me if I am wrong; to build a twin plug ignition all you need is:
12 - 2005 ZX650R COP coils; $200 Ebay
6 - lower cover plug wire holders; $66.50 Pelican
1 - 3 coil electromotive controller; HPV-1? HPX? Tec1?
1 - crank sensor; $10 Detroit type Ebay - hand built mount
1 - Toothed crank timing wheel; $25 Aftermarket Ebay
1 - spool of wire to build the low voltage harness
Is this right?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-14-2008, 02:41 PM
Our Twin-Plug DIS is on the way... currently we are still in testing with it.
A prototype was on display at SEMA, and will also be on display at PRI. It will include an internal rev limiter and tach driver. It will be a drop in- plug in- system.
No mods required...
Food for thought...
Old 11-17-2008, 04:33 PM
kenikh's Avatar
No mods required...
Food for thought...
http://compu-tronix.com/DIS6911.htm
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-17-2008, 04:42 PM
Originally Posted by oemexp View Post
Yes. Also, Bob is correct. All you need is a single 3 coil electromotive controller. You remove the coil packs. There are 2 prongs under each coil. From the hot wire under each coil, you run 4 wires (1 each to the hot side of the twin coils on each cylinder the electromotive coil would normally fire to, 4 wires total). You also need to run the ground pin to the same 4 coils (ground pin on the coils). You do this for each of the three coil pack signal prongs on the Electromotive controller plate. Keep the second controller as a backup. I don't have pictures (sold my air cooled race engine with the system on board).
The controller charges the coils, then the ground circuit is closed when the computer wants the coils to fire. You don't have to worry about cross fire problems because the wires only transmit 12 volts. Bundle the wires into a nice harness around the engine compartment or on the motor. I make up RSR type clips to hold the coils from vibrating out of the spark plug holes. The coils are heavier than the Porsche boots and will fall out faster than the boots will.
Mark,
So the Kawasaki coils are being driven by 12 Volts and the Electromotive Controller? (Best I can tell from Kawasaki service manuals is that the coils run on 100 volts).
Also, other than getting a wiring harness is there a source or part number for the connectors for the coils?
Paul
Old 11-19-2008, 05:34 PM
This is great.... I already have a dual plug setup using a mazda distributor for crank angle sensor ( 24/2 teeth). I have 2 ignitors and an EMS Stinger ECU. The setup uses 2 Ford tripple coils packs ( dual poll ). This gives a wasted spark system.
I have been looking at ways to eliminate the colipack and COP loks good. I am about to replace the wiring harness as it is a hashup of the original one from the previous owner.
I will replace the harness and leave enough space to change this to a COP via a plug.....this way I can change back to the original if it proves to be more trouble than it is worth.
let me know how things progress with this project...
Cheers
Mark.......
Old 11-20-2008, 09:59 PM
sjf911's Avatar
Anyone have ideas for 3-channel ignitors that could handle the pencil coils and sources/costs? Are there potential used sources in the U-pull junkyards?
Sapere aude
Old 11-23-2008, 09:43 PM
