Forced Induction Junkie
Sorry. If you look on the web page, the password is next to "PASS"........it's "wiringdiagrams21.com"....no quotes. good luck.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
I am a little confused...
Are you trying to fire more than one coil at a time with same ground trigger wire from the ignitor/controller? Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Wer bremst verliert
Its a 48MB file so no postie here. Its 125 pages of delight. Lots of detail there, I'll have to take a look later at the ignition sections...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
This COP solution is incredible. How well do the lower plug coils handle the exhaust heat? Please post some pictures of your setup and 3 coil controller.
I assume that you are actually producing a "pseudo-wasted spark" ignition with this scheme, is that correct?
Steve Sapere aude 1983 3.4L 911SC turbo. Sold Last edited by sjf911; 11-12-2008 at 03:20 PM.. |
3 restos WIP = psycho
Yes, pics tell a thousand words and I am reaaaally interested in doing this for my car.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Subtract $175 for the controller wheel...you can graft a cheap toothed wheel onto your existing crank wheel for about $25. Subtract the $500 for head machining, since that is assumed. Twin plug for under $400. Compelling? YOU BET YOUR SWEET A$$!!!
I still want to see the setup and wiring for a vehicle running 12 plugs and only 3 ignitors....
Cheers
I can see two modified HPV-1 modules required for something like this.
Wer bremst verliert
I run 2. Not sure how 3 works?
I would be a lot more interested in how you can fire a six cylinder engine with 2 ignitors...
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Navin Johnson
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Actually, "waste spark" is a misnomer in this case. A true "waste spark" system uses one double ended coil for 2 cylinders, and a common high voltage circuit for 2 spark plugs. If you could, without shocking the bejeezus out of yourself, pull one plug wire, you would kill two cylinders. What makes it work is that the inert exhaust gases in the non power producing cylinder have very little resistance to a spark jumping the plug, so the voltage goes to the cylinder on the compression stroke.
This system uses a pseudo-waste spark system. It triggers 2 separate coils, one on the exhaust stroke of a cylinder, and one on the compression stroke of a different cylinder. More efficiency can be gained by using a true sequential ignition system. Don't get me wrong, this is a very ingenious way to setup your ignition, and I am sure it works great. I am taking note of this for my project. But for the cool look factor, I am probably going with an old school RSR Style twin plug distributor.
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
Actually, it looks like it triggers 4 coils simultaneously, 2 on the compression stroke and 2 on the exhaust stroke like wasted spark which would use only 2 coils for the same number of spark plugs.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Wer bremst verliert
Mine is Accell 6-tower coils (same as EDIS-6) with a pair of triple-channel Haltech ignitors. I have burned through 2 Haltechs.
So correct me if I am wrong; to build a twin plug ignition all you need is:
12 - 2005 ZX650R COP coils; $200 Ebay 6 - lower cover plug wire holders; $66.50 Pelican 1 - 3 coil electromotive controller; HPV-1? HPX? Tec1? 1 - crank sensor; $10 Detroit type Ebay - hand built mount 1 - Toothed crank timing wheel; $25 Aftermarket Ebay 1 - spool of wire to build the low voltage harness Is this right?
Our Twin-Plug DIS is on the way... currently we are still in testing with it.
A prototype was on display at SEMA, and will also be on display at PRI. It will include an internal rev limiter and tach driver. It will be a drop in- plug in- system. No mods required... ![]() Food for thought... |
http://compu-tronix.com/DIS6911.htm
Mark, So the Kawasaki coils are being driven by 12 Volts and the Electromotive Controller? (Best I can tell from Kawasaki service manuals is that the coils run on 100 volts). Also, other than getting a wiring harness is there a source or part number for the connectors for the coils? Thanks Paul |
This is great.... I already have a dual plug setup using a mazda distributor for crank angle sensor ( 24/2 teeth). I have 2 ignitors and an EMS Stinger ECU. The setup uses 2 Ford tripple coils packs ( dual poll ). This gives a wasted spark system.
I have been looking at ways to eliminate the colipack and COP loks good. I am about to replace the wiring harness as it is a hashup of the original one from the previous owner. I will replace the harness and leave enough space to change this to a COP via a plug.....this way I can change back to the original if it proves to be more trouble than it is worth. let me know how things progress with this project... Cheers Mark....... |
Anyone have ideas for 3-channel ignitors that could handle the pencil coils and sources/costs? Are there potential used sources in the U-pull junkyards?
