Try not, Do or Do not
Henry Schmidt's Avatar
RS longblock ordered on 4/28/09
Our customer requested a 2.7 RS spec long block on April 28, 2009.
She's ready to ship today. Sometimes things just fall into place.
Dow dry film coating.
Cross drilled crank. In house one day
Grooved bearing, enlarged feed hole.
2.4 S nitrided rods
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-07-2009, 02:26 PM
3.0 908 style oil pump with Supertec oil pump modification.
Supertec head stud kit
Henry Schmidt
Ph: 760-728-3062
Old 05-07-2009, 02:29 PM
Supertec tensioner arms
Henry Schmidt
Ph: 760-728-3062
Old 05-07-2009, 02:31 PM
Henry, you have one of the greatest jobs in the world......and by all accounts you do it very well.
I always know I'm going to see something great or learn something new from your posts. Always with clear pics.
John
Old 05-07-2009, 02:35 PM
You make it look so darn easy nice work.
Jerry McAbee
1967 912
1968 912
2002 Tundra 4x4
Old 05-08-2009, 12:07 AM
Fast Corners's Avatar
Drool!
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 05-08-2009, 01:16 PM
shbop's Avatar
Originally Posted by jcge View Post
henry, you have one of the greatest jobs in the world......and by all accounts you do it very well.
I always know i'm going to see something great or learn something new from your posts. Always with clear pics.
john
+1
Jon
Old 05-08-2009, 04:06 PM
juicersr's Avatar
Wow, magnificent. That thing is a piece of art.
Could you explain the benefits of 'Dow Dry film coating'?
How does the 3.0 908 style pump differ from a standard SC style pump?
Finally, are those tensioners purely mechanical?
BTW, thank you for helping me with my cams and working with Dougherty. Engine is together and back in car. Should be firing up soon.
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 05-11-2009, 01:22 PM
Dry film lubricants are solid materials that provide low frictional resistance between surfaces when applied directly to interacting surfaces. Each material has different properties. Crystalline lattice (lamella) structure materials, such as molybdenum disulfide, tungsten disulfide and graphite, are widely used as agents in lubricants and as stand-alone lubricants. These materials are used independently or in combination with other agents and metals (lead, copper) to achieve the desired results. Lamella lubricating powders have low shear forces between their crystalline lattice layers that minimize resistance between sliding surfaces.
Research shows Moly when combined with oil is perhaps a 1000% better at reducing friction than oil alone.
The 3.0 and 908 pumps have the same basic design. The 908 pump was mag and the 3.0 SC pump was aluminum. My statement should have read 3.0/908 when attempting to describe the type of pump.
The magic to the pumps we run is in the port work we perform on the inside of every pump we use. Test show a 15% flow improvement over the stock pump configuration.
This engine was assembled with 930 Turbo tensioners with chain savers added. This aids in maintaining a period correct appearance. What you see in the pictures are tools used to set the cam timing.
You are welcome, I was glad to help.
Henry Schmidt
Ph: 760-728-3062
Old 05-11-2009, 02:14 PM
Another work of art - and another happy customer
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-11-2009, 09:47 PM
'Tis indeed a work of art. Makes we want to do it all over again. Bigger is better, right?
1972 911T/S MFI Survivor
Old 05-20-2009, 10:38 AM
Henry, No power Pully??
Engine looks great.
On a side note, ARP is now offering stud sets for the engine cases (not the cylinder studs)
Sounds like a waste? Maybee you and I can go into business making carbon fiber component for the engine and make a fortune.
O22$pa
70 porsche 911t
52 mgtd
Old 05-20-2009, 12:03 PM
Insane Dutchman
Great job Henry, makes me drool.
I notice that you have cad plated or zinc dichromated the through bolts....did you heat treat them after plating or are you being *brave* and just puttin them in as they are?
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 05-20-2009, 02:48 PM
al lkosmal's Avatar
Henry,
You set the bar higher.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 05-20-2009, 10:11 PM
Very nice work!
If you don't mind me asking;
What processes are you using to get you engine parts so clean with such an even surface finish?
Your timing covers and boxes look flawless!
Also, what plating process are you using on the fasteners? They are very bright and look awesome!
thanks,
-Adam
Old 05-23-2009, 01:33 PM
