What about a ZF box?
They can be had for around 10 G's, much less than cup car boxes. The ZF can probably handle 1st gear launches, although if you can live without 1st gear clutch drops, then that opens up a few other possibilities. My race car has 350hp and 350+ torque and has been raced for many years with a "wevo-ized" magnesium 915 box. Custom geared 930 box would be hard to blow up. "The race car sales site" has a "gearboxes" section with many exotic transaxles, you might look there. A "Real" gearbox that can handle abuse will run 20G's or more. |
The Ultima GTR is mid engine and many have inverted G50's.
Many have well over 500HP. The Ultima GTR - Z06 Powered Racer - Car Craft Magazine
Doug Crossman #92 1992 964 PCA G class #902 1979 911 PCA 911 Cup 96 993 Targa |
120 HP/Liter is all I ask
Looks like the 1/2 shaft is at quite an angle in the Ultima and the CV presumably is surviving. Also I think the same was the case for the 9ff Cayman shown in Excellence some time ago that had a Turbo engine with upside down 6 speed.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche |
BTW, here is a good vid: YouTube - radical sr4 sequential onboard @oulton park 07 Last edited by blue72s; 07-04-2010 at 08:20 PM.. |
It depends on the box and the engine management.....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Author of "101 Projects"
There's a lot of smart people here in this forum! I would perhaps suggest a 959 transmission, as I know where you could get one. Probably not suitable for your application though - sounds like 962 is the way to go.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
There is a guy who is always in the Subaru Forums that had a ring and pinion made for a Subie box that reversed the rotation, perhaps this is a way to go for you? The problem is he had to get it made in India and the first set was about 10k sets after were cheaper. Here is his website http://www.subarugears.com/index_files/Page388.htm
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena Last edited by MarKoBrow; 07-05-2010 at 05:50 AM.. |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Max Sluiter
What about the casing that carried the suspension members?
The PDK was all-new, anyway.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
gearhead
The Subaru 5MT was originally designed for a 2WD car that had about 180bhp. When they started chasing WRC titles and getting serious about rally they added a rear differential to the same gearbox and started putting the Ej20G engine against it. Initially those were 250bhp in Group N trim. Over time power levels went up, and by the time the 6MT gearbox was released the last generation of Ej207 engines was putting out a published 280bhp, and was often engine dynoing in stock trim right out of the box upwards of 350bhp. And by then they were consistently breaking gears in races and came to be known as the "glass gearbox". Now let's take that gearbox and consider putting it against a 400+bhp GT3 engine. At that sort of power level (which is not uncommon in Ej205 powered "bugeye" WRXs) these gearboxes break second gear all day long. It just can't take it in stock form. And this isn't even taking into account the 2WD conversion. When in a Subaru they are a 50/50 F/R power split. The forces are shared over 2 ring and pinions. Putting all the power to the front one is way past what these things were designed for. If you're gonna even consider the Subaru 5MT gearbox for this sort of usage, not only will you want a replacement ring and pinion, but you'll want to replace all the gearsets. And you are also going want to add an LSD to it so that you can get the power to the ground since the front differential on that box is open from the factory unless it was a special STI-RA variant, which is hard as hell to find in decent condition. You're going to spend $10,000-$15,000 beefing up the Subaru gearbox to make it work for this. For that kind of money there's many other boxes one can buy and not have as many issues in making it work right in this particular application.
Maybe a Quaife Q-Tek 6 speed shown on the left, which has all the dimensions of the latest 996 gearbox could be used. It is designed for mid-engine or rear engine use.
Quaife do make a variant of this gearbox as a kit to go with the non-GT3 911 engine, which is shown on the right with the gear lever. The kit also includes clutch and flywheel in addition to bellhousing. I understand they are now making a kit for the GT3 engine, which if set up for mid-engine use would work for a Cayman. Available with helical gears for "road use", but it is a dog clutch gearbox. ![]()
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche Last edited by Cupcar; 07-05-2010 at 12:59 PM.. Reason: Clarity |
Hey Matt, I was actually suggesting that he get a ring and pinion made for the G50 transmission and I was using the subaru transmission as an example. this way he could get to use a G50 in it's stock configuration yet have it rotate in reverse. Perhaps this is right up your alley?
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena Last edited by MarKoBrow; 07-05-2010 at 03:42 PM.. |
gearhead
![]() Unfortunately we don't cut ring and pinions in house. It's something we have done by Ricardo and the minimums to get it done are a dozen units and the lead time is about a year. Though it may be the kind of job that Albins is interested in doing. They've got their own Klingenberg machine and will work in smaller batches. It definitely wouldn't hurt to contact them and see if it's something they would at least bid.
Thanks, it makes sense. I remember I test drove a BMW with SMG gearbox, which is essentially sequential but with syncros. The throttle blipping during downshifting was done automatically by the engine management but rather slow, nothing like in the above video. I think the reason for slowness was due to the heavy (OEM street) flywheel/clutch assembly, and of course the syncros.
Anyway, if a true sequential transmission (dog box) was fitted with a street version flywheel/clutch, the downshifting process would be slow just like the BMW, wouldn't it? I'm not sure if a lightened flywheel with say 5.5" triple plate clutch could be used for street as a daily driver?
The management needs a signal to to cut ignition on the upshift or blip the throttle on the downshift, usaully a microswitch in the shift lever. You would need to make sure your chosed ECU can do this. Otherwise you just end up with a sequentially shifting box that requires clutch and manual throttle blip on down shift, which is not a bad thing!
Anything you can do to reduce mass in the rotating assembly aids in the speed at which the motor will increase/decrease revs. The rest of it is in the tuning of the ECU. The VW/Audi DSG rev matches quite quickly. Cheers
3 restos WIP = psycho
It was my understanding that you cannot flip the R&P in a Subaru transmission to get reverse rotation, which is also the case in the GT3 box.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Doesn't the casting pocket for the shift rails protruding in the diff case get into the space the ring gear would occupy on the opposite side of a G50, thereby preventing a flip of the ring gear?
