BING! The light bulb came on. That is information that I did not have before. Which is why I specifically called out the basis of my statements and that they may be the exception and not the rule. Since my limited knowledge does not apply here, I respectfully will be quiet now. Carry on. I am interested in the answer as one dream I have is putting a GT3 engine in a 914 and I will need a trans that will take the punishment, but I'll probably invert a GT3 trans.
John Flesburg 2016 981 Boxster S.................| 1983 911 Turbo - (White) 1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver) 1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?) 1971 914 (TBD)..................... | |
1997 911 Carrera Cabriolet 66 912, 67 912 Outlaw 65 Ac Cobra reproduction 2012 Audi A8L 1999 Ferrari 360 Modena |
John, I'm glad we cleared that up for you. Just remember if you do invert the gt3 box you will need some sort of oil pump and sprayer onto the r&p because otherwise they don't get enough oil. The result is pretty messy. I brought an older g50 out that had been in a lambo replica and it had broken teeth on the pinion which were then forced out the side of the box as they jammed in the reverse gear idlers!
A tdi box sounds promising because it may be able to handle the torque that the lambo guys love from their v8's. Maybe we can get this Back on track for blue72. |
I did in fact drive the car around the block 4 forward speeds and reverse, I now have to figure out what I may have done to my shifter assembly so I can get into fifth gear. Next radiator and water management.
Did you happen to see the note I left about the Audi 6speed 2wd TDI trans? I am curious to hear your thoughts on that transmission assembly.
Max Sluiter
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
. Just wanted to warn you before you wear it out even further so you could try to send it back for a refund. Good luck. Don't believe me? Check your R&P.Quote:
I just went back and read the product description on subarugear's site. I was mistaken about the purpose of the "reverse cut" R&P. It is not made for reverse rotation engines but is intended to allow the the tranny to be reversed by flipping the R&P. The subie diff uses an offset pinion shaft (the pinion axis does not intersect with the ring gear axis) so the stock gear would not mesh if flipped. This product is ground to mesh when flipped to the other side. As your car has multiple speeds forward you can be sure that your shop followed the instructions and flipped the (new)R&P into the right case. These gears would not mesh of someone tried to install them in the stock (left case) location. Glad it's working out for you.
regards, Phil |
![]() ![]() Blue 72 The pic you posted is of opposite rotation R&P sets (from what I don't know). The gears in question are shown in the enclosed images from the subarugears website. The first shows the stock R&P in the standard location (left case). You can easily see the pinion offset and why these gears wouldn't mesh if flipped. The second shot shows their custom ground gears mounted in the right case. They are ground to allow a mesh even though the pinion is now offset on the other side of the ring gear axis from the point of view of the ring gear. Note that the drive and coast faces remain in the same orientation and skew direction is the same. regards, Phil p.s. I also have a blue '72 |
I was surfing the net and found Rodrico gearboxes. You should look into those for sure. They are the boxes used in the Ford GT. Price looks promising.
However, motor car manufacturers never do that. Why I don't know. |
You are correct; I should have read the captions more carefully. However, the point remains; the reversal is accomplished by flipping the ring. The gears are ground to allow this.
regards, Phil |
gearhead
And furthermore, as was previously mentioned, the box has some strength issues. I think they can get away with using this gearbox in the TDI cars because they just don't see the sort of stresses that are seen on a gearbox used on the track for extended periods of time.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I'm certain it is not good practice, but if you want to reverse the rotation, the ring gear must be flipped and this is the only way to do it other than turning the whole box over.
regards, Phil |
Hello again guys,
You are probably right but unfortunately the 962 casing has a "nose" around the input shaft. See pic below. ![]() If I get one for my application, obviously I would have to cut its nose off completely and also make a bellhousing. The going value of these gearboxes in Europe is about 25,000 €uros, which is a lot of money. Naturally, I have to think about future resale, so what I need to know whether cutting the nose off would greatly devalue the gearbox or worse - render it useless for 962 cars? I have located one for sale and I'm not sure whether I should buy it. What do you guys think? Is it too risky? Last edited by blue72s; 09-22-2010 at 05:57 AM.. |
