Converting a GT3 engine to reverse rotation?
What do I need to convert a GT3 motor to reverse rotation? I know that one of the requirements is a crankshaft with rod-journal oiling passages drilled to the opposite side of the rod throws in order to support the reversed bearing load phasing, so can you tell me if a standard GT3 crankshaft already has that (drilled on both sides)?
Old 06-27-2010, 05:37 PM
Navin Johnson
TimT's Avatar
Flip the ring and pinion......
'69 911 GT-5
'75 914 GT-3
and others
Old 06-27-2010, 05:50 PM
^That would be nice but the GT3 ring gear is not flippable. I'm not prepared to use a 915 and the 930 box only has 4 gears.
Old 06-27-2010, 06:37 PM
I'm not familiar with the GT-3 engine but I suspect there is a lot more involved. Things like the cam drive geometry (tensioners are on the "undriven" side of the chain) and oil pump only work for one direction.
-Andy
Old 06-28-2010, 05:19 PM
Its quite a challenge to reverse the engine rotation on these,.....
IMHO, its FAR FAR easier to mount the transmission upside down for a mid-engined car.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-28-2010, 05:21 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Why would you want to? For a mid-engined car?
Scott Kinder
kindersport @ gmail.com
Old 06-28-2010, 06:15 PM
Max Sluiter
Flieger's Avatar
Maybe he wants counter-rotating GT3 motors for his bass blaster.
Old 06-28-2010, 07:53 PM
YTNUKLR's Avatar
Haha. Couldn't you just put the intake on the bottom and run the headers out the decklid? :d
Old 06-28-2010, 07:58 PM
If I flip the trans, the output shafts would be about 5" too high. Sorry, that's not acceptable.
YTNUKLR - Yep, mid engined.
Old 06-28-2010, 09:05 PM
YTNUKLR's Avatar
G96/96? Can you lower the engine/trans.? You can't flip the ring because it's hypoid, right? Isn't there a G50 variant you could flip the ring on(I have never worked on G50s)? Is this for a 914 or something else?
Old 06-28-2010, 09:23 PM
3 restos WIP = psycho
kenikh's Avatar
Welcome to Mendeola Transaxles!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-28-2010, 09:49 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Hewland sequential gearbox
Hewland Engineering Ltd | Gearbox Range
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 06-29-2010, 04:27 AM
120 HP/Liter is all I ask
GT1 Gearbox from Porsche...bring money.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 06-29-2010, 08:31 AM
Both Ricardo & Xtrac make custom transmissions for such applications and while not cheap, they are THE best.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-29-2010, 08:47 AM
Originally Posted by kenikh View Post
Last season our 4.0 two valve engine broke the big Mendeola twice.
Surpised me.
Henry Schmidt
Ph: 760-728-3062
Old 06-29-2010, 08:48 AM
Aren't all the Mendeola, Hewland, Ricardo, Xtrac etc. non-syncro?
Old 06-29-2010, 10:31 AM
Ricardo, & Xtrac will do syncros, a dog box or sequential by request.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 06-29-2010, 11:25 AM
Why sequential?
Old 06-30-2010, 09:56 AM
The GT1 'box is actually upside down. Again not suitable for me.
Old 06-30-2010, 09:57 AM
Good to hear. I will check it out.
Old 06-30-2010, 10:00 AM
