help can't find the serial number
we just bout a sand rail with a Porsche motor in it. we were told that it was a 911, 3.0 Lt. but i can't find the numbers to look it up. we pulled the fan and alternator, distributor, and the little triangle heat shields on the left and right of the alternator.
we have looked all over the motor and just cant even find a block number. any help will be great. here is a pic of what the motor looks like, hope that someone will recognize the layout of it and be able to tell me where to look.
thanks in advance for the help!
Old 09-30-2010, 04:28 PM
Engine serial number.......
The engine serial number for 911 is located some where below and right side of the alternator fan housing. Somewhere between 4 and 5 o'clock position. Just behind the alternator belt shown in your picture. Post another picture of the engine with the correct orientation for easy viewing. That would help too.
Tony
Old 09-30-2010, 06:03 PM
Wrong coil, wrong fan and wrong crank pulley
Bruce
Old 09-30-2010, 07:56 PM
The S/N is found on the RHS of the alternator stand as shown in these pics.
If the engine were from a 914-6, the S/N would be on the top of the case next to the breather cover.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-01-2010, 02:56 AM
Bruce
What would that fan, crank pulley and coil be off of then? That is what I need to find out.
Old 10-01-2010, 07:48 AM
here are some better pic's
this engine has a oil sump on it. if that helps
the carbs are aftermarket, but everything else is stock as far as I know.
Old 10-01-2010, 08:46 AM
here is pic of the engine top and RH head/ spark plug area
thanks again for any help
Old 10-01-2010, 08:49 AM
Anyone?
Old 10-05-2010, 04:01 AM
The fan pulley is too small for an SC, its an early car fan and pulley, pre 77. The fan you want has 12 small holes in groups of 3 where the large holes in the fan are. The combination of pulley and proper fan supplies more air to the cylinders.
The coil that matches the Permatune CD box in the picture is a Bosch that the part number on the end of the coil ends in 001. Visually the Bosch coil is 2/3 the size of the one in the picture.
You need better pictures of the right side of the fan in that whole area.
Bruce
Old 10-05-2010, 04:59 AM
djpateman's Avatar
You have a good photo of the area where the serial # should be. Since it is not there, you must have an un-numbered replacement case. So, what you have there can only be determined by a full strip-down, and each part identified.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 10-05-2010, 06:38 AM
Check the area on top of the case between the breather cover and the T-Stat for a 914-6 serial number and type number as shown below.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 10-05-2010, 09:23 AM
here is numbers off the block from the bottem of the motor
Old 10-07-2010, 07:19 PM
djpateman's Avatar
Okay, so the 7R at the end identifies it as the last incarnation of the magnesium case and was introduced in the latter half of 1973 as a 2.4. It was better known as the case for the 2.7, and was the strongest of the magnesium cases. I suppose it is possible it was built as a 3.0, but as I said before only a teardown will identify what you really have.
Addicted since 1975
Old 10-08-2010, 07:47 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I have a 964 engine that was purchased directly from Porsche and never installed in a 964. It has no s/n. I was surprised when I bought it (from original owner) about the lack of s/n, but the story from the original owner seemed totally logical. I asked around at the time and everyone seemed ok with the story, though no one could confirm definately that Porsche sends engines without s/n.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 10-09-2010, 03:17 PM
TibetanT's Avatar
Is this motor out of a Porsche 911 2.0L/2.2L?
From the pictures, Hmmmm? Just wondering.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 10-14-2010, 10:39 PM
TibetanT's Avatar
Whoops! My mistake...too quick with the mouse button.
Sorry about that.
Ed Paquette
1983 911SC
1987 944S
Old 10-14-2010, 10:41 PM
