jamesjedi's Avatar
Engine Cases
I have been looking at different engine cases. I have noticed that there is not a great difference in price between the 3.2 and the 3.3 engine cases. Is there a benefit to using a 3.3 engine case to build a normally aspirated engine?
Old 11-13-2010, 05:44 PM
Forced Induction Junkie
WERK I's Avatar
Yes, if the 3.3l case also happens to contain the turbo oil pump.
Trying to remember if the 3.2 case had the oil squirters like the 3.3l does for piston cooling.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-13-2010, 06:05 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
The case for 3.2 and 3.3 is the same.
The 3.0 case is really similar, but has the sump plate on the bottom rather than just a drain plug.
Scott Kinder
kindersport @ gmail.com
Old 11-14-2010, 12:43 AM
As Scott points out, the 3.2 and 3.3 cases are the same and differ from the SC case only in the replacement of the sump plate with with a drain plug. Both have piston squirters
The attached pics show the difference:
SC case
3.2/3.3 case
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 11-14-2010, 01:05 AM
jamesjedi's Avatar
That is amazing. Thanks for the information. Sounds like value would depend on whether or not the case came with a turbo pump?
Are they better than the 3.6 case, or are they basically the same?
Old 11-14-2010, 03:47 AM
3.2 case
The other plus of a 3.2 or the late 3.3 is if you plan to run EFI or management, those cases have the mounting points for the crank reference sensors. The squirters can be changed to the larger ones if you need them. The 3.6 case is a completely different animal.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-14-2010, 05:49 AM
jamesjedi's Avatar
I found 79 turbo case. Which I believe would be a 3.3. I assume this is not the same case as the late 3.3 cases. Do the later 3.3's have the larger squirters?
Old 11-14-2010, 07:01 AM
The 79 3.3 case will be the same as the SC. Generally the oil pump is priced separately.
Bruce
Old 11-14-2010, 01:56 PM
jamesjedi's Avatar
OK, I see. There would be no advantage unless it had the turbo oil pump. Sounds like I will need to get a 3.2, or wait to see if a 3.3 with turbo oil pump comes up.
Unless the turbo oil pump bolts onto the 3.2?
This is such a good site!
Old 11-14-2010, 04:25 PM
You can use the turbo pump with the SC case. You'll need to use a "dished" sump plate to clear the screen on the turbo pump suction inlet.
Tom Butler
1973 RSR Clone
1970 911E
Old 11-14-2010, 06:30 PM
Just a small tidbit to add: Beginning around mid-1983 model year production, SCs have the later Carrera engine case with the drain plug instead of the sump plate.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 11-15-2010, 10:00 AM
jamesjedi's Avatar
Which cases has the large spiston squirters?
Old 11-15-2010, 10:36 AM
case
I just checked a 930/04 case 78/79 3.0 SC its squirter is .039 in, I have an 89 3.6 and it pins out at .084 in, I will look to see if I have a 3.2 case
Mike Bruns
Old 11-15-2010, 10:52 AM
I am wondering which case is stronger with regard to high-rpm 3,2SS build - should I base it on an a 3.0 SC or a 3,2L case?
Old 11-15-2010, 11:41 AM
cases
I have used both styles over the years on some very powerful 3.0 and larger race setups and have had good results, If I had a choice I would use the later style but that does not mean I would avoid the earlier, I like the way the scavenge pickup looks in the later case and it has to be stronger by design with full perimeter contact.
Old 11-15-2010, 12:05 PM
YTNUKLR's Avatar
3.0 1978-1983
No crank reference sensor mounts
Accepts Turbo oil pump
Standard piston squirters
Sump plate like early cars
3.0 1983.5
No sump plate, looks like later cars (1984-1998)
3.2 1984-1989
Crank reference sensor mounts
3.3 early
Turbo (large) piston squirters
3.3 late
Turbo piston squirters
Does this help you?
They are all basically the same. You can weld on the mounts for reference sensors, the sump plate is not that big of a deal, you can retrofit larger squirters in a standard case.
BTW, I have a 3.2 case, PM for details.
Scott Kinder
Old 11-15-2010, 12:33 PM
jamesjedi's Avatar
That is excellent help. On a side note, I have been shopping around for cases. I have found that there are large variances in pricing. There are deals out there, I even found a reputable dealer who said that he has a GT3 case for $1500. He does not have any Turbo or 3.2's, but I am hoping to go see what he has. He gave me an interesting run-down on pricing. It seams like the key is to be patient.
Thanks everyone.
Old 11-15-2010, 05:29 PM
djpateman's Avatar
Scott, that is a very good reference. Could you put case casting numbers to those versions? I'm guessing 930.101.103.4R & 930.101.104.4R for the first version.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-15-2010, 08:20 PM
jamesjedi's Avatar
The information must be in a chart ....somewhere on-line.
Old 11-16-2010, 06:51 AM
djpateman's Avatar
This is my own chart, started just recently because I could not find such info anywhere else:
911 engine case Revisions
Addicted since 1975
Old 11-16-2010, 09:45 AM
