cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
2nd tIme I did it I built a basic hoist with 4x4's and a comealong. Worked perfectly. Have a pic somewhere.
Chris
Old 04-06-2022, 08:30 AM
Jeff Alton's Avatar
Lift tables are what we use. But we routinely have 3-7 engines on stands so it makes sense to have 3 lift tables. We use the table for engine removal/install and on/off engine stands. Super easy. Not necessarily the best option for DIY one time use.
I have one of the jack adapters we bought years ago to do it on a floor jack. It worked for in/out but you need a really high lift jack to get it onto a stand.
www.turn3autosport.com
Old 04-06-2022, 10:34 PM
al lkosmal's Avatar
+1 for using a lift table. Makes it much easier.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-07-2022, 06:47 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Lift table is the best way but if you have a hoist (2 post) you can also use one or two of the arms to raise and lower your engine. Just strap it to an arm.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-07-2022, 08:53 AM
Jeff Alton's Avatar
Had the lift tables occupied, used Henry's idea with the 2 post. Worked great. very easy.
Cheers
Old 04-14-2022, 08:47 PM
Hi everyone,
I made a video of my son and I moving engine from stand to lift without a cherry picker. I don’t have the very first step but describe it in the end.
It’s on my YouTube page. Here’s the link:
https://www.youtube.com/watch?v=BX2jOT9BeK4
Cheers,
Mark
1989 911 Carrera 3.2
2009 Audi A4 2.0TQA
2017 BMW X3
2007 BMW 328xi
1971 BMW R60/5
Old 04-15-2022, 07:29 AM
This is how the Pepe’ (tiny dog) and I do it.
Getting the engine on the stand was easy.
Getting it back down was difficult. I had to find something tall enough to support while allowing me to fit an ATV jack under. Then lower it in increments. Jenga anyone?
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-15-2022, 05:32 PM
Some of the Scariest Things We Do..........
This is probably the scariest procedure in this thread and would never consider recommending it to people I care about. One wrong move and disaster could strike causing major physical injury or worse death. This is like playing a Russian Roulette that involves too much risk. The two (2) tires make me cringe just to look at this set-up. Of all things why use a set of tires? Just my two-cents.
Tony
Old 04-16-2022, 05:32 AM
Originally Posted by boyt911sc View Post
This is probably the scariest procedure in this thread and would never consider recommending it to people I care about. One wrong move and disaster could strike causing major physical injury or worse death. This is like playing a Russian Roulette that involves too much risk. The two (2) tires make me cringe just to look at this set-up. Of all things why use a set of tires? Just my two-cents.Tony
Yeah looks pretty sketchy (maybe you had to be there?) but I do like those polished Fuchs. 17” Braids?
If you’re a gearhead or enough of one to R&R your own engine, it’s worth getting a cherry picker. They pop up on Craigslist now and then for dirt cheap money. You’ll end up using it once you have it, saves your back, and allows you to solo a lot of projects that would have required more coordination with helpers. And lending it out a lot.
Ken
1986 930 2016 R1200RS
Old 04-16-2022, 09:03 AM
Tony
Totally agree, not recommended. I moved recently and really wasn’t set up for doing this work when my clutch went out. The picture makes it looks a lot worse than it was, the tires were the only thing I had high enough to work and they weren’t rolling or wobbly. Not the best, but certainly not at risk of falling.
Old 04-16-2022, 05:20 PM
15” Genuine Fuchs. And yes, you had to be there.
Old 04-16-2022, 05:22 PM
