removing cam nut with-out proper tool(can it be done)
Has anyone removed this nut without the crowfoot tool.
Old 01-28-2011, 01:20 PM
A chisel and a hammer works as long as you don't plan to reuse the nut.
Lindy
Old 01-28-2011, 01:41 PM
Dr J's Avatar
It's in there pretty tight. Get the tool. Then sell it. It will sell like a hot potato.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 01-28-2011, 02:07 PM
Try not, Do or Do not
Henry Schmidt's Avatar
A rock and a piece of rebar? Just teasing.
You can use a socket and a 1/2 impact gun to take it off. Just leave the chains and tensioner in place. This method is not recommented for installation.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-28-2011, 02:27 PM
An impact wrench does this every time.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-28-2011, 05:05 PM
Consider this alternative... a large socket wrench with the side cut-out to stick a wrench inside to hold the cam. Admittedly a bit "Mickey Mouse", but I've used these many times over the years with no problems.
Old 01-28-2011, 07:02 PM
Almost Banned Once
sc_rufctr's Avatar
Is the crow foot expensive?
Compared to the cost of a rebuild... I say spring for the money and buy one.
Then sell it if you have to on here or fleebay.
When you have the right tool for the job the job is a whole lot easier IME.
- Peter
Old 01-29-2011, 06:32 AM
I would rather be driving
jpnovak's Avatar
Just buy a 4WD socket and use an impact wrench. Off in a matter of seconds.
Old 01-29-2011, 07:15 AM
OldTee's Avatar
That was my suggestion to him in PM but I couldn't remember the socket size.
45mm????????
To keep the chain tight use some vice grips to hold the idler arm firm.
Old Tee
all 911s sold
Old 01-29-2011, 09:12 AM
Irrationally exuberant
ChrisBennet's Avatar
If you put your location in your profile, someone near you might offer to lend you the tool.
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-29-2011, 01:29 PM
thank you all very much
ed
Old 01-29-2011, 04:44 PM
Impact wrench sounds brutal. The chains will take a beating as there is little moment of inertia in the cams. On the other hand if it is normal practice it is tempting.
Is there any way to know which tool will I need for my 80SC ?
cam nut tool (1965-80) PEL-TOL-P202 or Cam Bar (1980-89) PEL-TOL-P237
I would rather not have to wait for long lead tools
80SC (ex California)
Old 02-02-2011, 05:58 AM
