PFM PFM is offline
PFM
PFM's Avatar
930LDR,
Nice work, the spun bearing makes sense at idle, my guess is oil pressure was a bit low at idle and got it. I would replace that rod regardless to how it checks out. How is the crank?
Looks like you will need a piston now for sure.
Stay Tuned,
PFM
Old 03-06-2011, 12:16 AM
350HP930's Avatar
Good work Rob, glad you managed to get in there.
Old 03-06-2011, 08:16 AM
What... don't think that can be cleaned up? Fortunately this was one of the pistons that had damage on the surface anyways. I may end up replacing the whole set and going 3.4L since there are a couple more less than perfect pistons in the lot.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 03-06-2011, 12:26 PM
Senior Advisor
James Brown's Avatar
Keep the piston and rod and mount it on a wooden base and hang it in your garage as a subtle reminder of the cost of speed!
08 Cayenne Turbo
Old 03-06-2011, 01:39 PM
As I'm looking at P&C options... any thoughts or recommendations on staying 3.3L or going 3.4L (or 3.5L)?
Rob Montgomery
Old 03-06-2011, 09:57 PM
CaptainCalf's Avatar
I read once that a good reason to go to 3.4L jugs & slugs is cuz the aftermarket cylinders run cooler due to a different fin arrangement then the OEMs, but I don't have 1st hand knowledge if it's true or not. Also, if you go larger then 3.4L then you have to bore out the case some to make room for the larger slugs.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 03-07-2011, 04:52 AM
I would rather be driving
jpnovak's Avatar
Great job getting that piston off. I am sorry I missed the point that the engine seized. I thought it was free and then was stuck after you put the top-end off.
Can you cut the remainder of that piston in half so we can get a measurement on the crown thickness?
This is important for those who want to cut valve pockets in stock pistons.
Thanks.
Old 03-07-2011, 05:56 AM
Alan L's Avatar
Well, I stand informed - a spun bearing under minimal load. Does that mean we should thrash them more regular?
I guess you had no other option. I cant see what else you could do, altho there have been many spun 930 bearings before. I guess it depends where the crank stopped and you drew the short straw.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-14-2011, 01:26 AM
Sorry... been off for a while on business...
Jamie - Don't mind cutting the piston and taking some measurements for you.
Alan - Definitely drew the short straw although a couple of the pistons had some detonation damage (including this one) so it would have needed to be replaced anyways...
Rob Montgomery
Old 06-14-2011, 08:01 AM
