CaptainCalf's Avatar
Plug
Originally Posted by 350HP930 View Post
Good find on the distributor plug Rick.
Flebay! $15 plus shipping just can't be beat unless you make your own...but I don't know anybody who has a mill for that kinda precision work
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 07-12-2011, 07:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
350HP930's Avatar
That would be hard to beat. If I made a one off like that the cost of raw materials alone would have run almost as much, lol.
Old 07-12-2011, 05:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Case saving measures required
I've got 2 iffy head stud holes in the left case that I'm going to repair with Time-serts, so progress is slowed a little. One of the holes wont hold torque even with green sleeve and the other holds with green sleeve, but if I'm gonna fix one I'll fix both while I'm there
Old 07-13-2011, 09:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Front wheel brg progress
The wifie asked if I'd PLEASE try not to make any banging noise in the garage early on Saturday mornings, so I decided to buy a silent banger
Grizzly 10 ton press...whattcha think?
The press made short work outta the front race installs
Seals are in so front ens should be done soon
Old 07-18-2011, 07:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
350HP930's Avatar
Good addition to the shop there Rick, one of those is on my wish list as well.
Old 07-18-2011, 08:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
new case threads cut for time-serts
I finally got everything together I needed to drill & tap the case for time-serts. It took a little while to figure out how to dill & tap with precision w/o using a drill press, but I gotter done so no porcupine case here
Old 07-22-2011, 08:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Front End Finished!
I'd rather build a motor any day then work on 24 year old front suspension parts, but it's done now so I can get back to the motor
Old 07-25-2011, 09:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
350HP930's Avatar
Don't forget that you still have the rear bushings and torsion bars to deal with, lol.
Old 07-25-2011, 02:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
Thanks a lot for the reminder...some new rear parts ordered
Old 07-26-2011, 05:20 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
350HP930's Avatar
My original plan was some slighly stiffer hollow bars for the rear to compliment the slightly larger front bars I passed on to you.
What did you get?
Old 07-26-2011, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
What did you get?
I'm going with a new set of Bilstein HD shocks in the rear from our gracious host, so for now I want to see what those feel like with the stock rear T-bars. I like to approach a stiffer/harsher ride in small increments. It's way too easy to go to far too fast
Old 07-26-2011, 06:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
time-serts in
Time-serts are done, so on to building up the cam towers next
Old 07-26-2011, 10:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
350HP930's Avatar
Before you put those jugs back on you might want to builld that base gasket area back out with some metal epoxy so it has a good sealing area.
Old 07-26-2011, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
Good eye! I was thinking the same thing, but decided it was overkill when I noticed some of the through bolts already had more material then that removed.
However, I did clean the mating surface on the case real good and added a little fresh sealant to the cylinder gaskets before dropping the jugs in the holes...nothing wrong with a little added insurance
Old 07-26-2011, 12:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
350HP930's Avatar
That should probably do then, digital photos often make it hard to tell just how thick something is.
I'm still left pondering why those two holes were so much worse than the rest.
Old 07-26-2011, 01:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
Don't ask cuz it was my fault. I buggered up the threads in those two holes otherwise they'd all have been fine...most were a little loose so I sured them up some with Permitex high temp green sleeve, but all in all that's one sweet case you had there...show's that even soft aluminum can be preserved if well cared for
Old 07-26-2011, 01:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
New rear brake lines
Starting on the rear end now. Replaced the old rubber flex hoses with SS lines same as front along with new lines to the calipers. Man it's hot in the garage right now!
Old 07-28-2011, 06:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
350HP930's Avatar
If that garage has a window you could always put a A/C unit in it. The one I have keeps the garage pretty cool when its on with the doors closed.
Old 07-28-2011, 08:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
Two windows! However, a window shaker unit would be frowned upon by the home owners association so I have a box fan I put in the window to circulate the hot swampy air
Old 07-29-2011, 06:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
350HP930's Avatar
Well that sucks, too bad those stand alone units with a duct to carry away the hot air are so expensive since that would be an option as well.
Congrats on ticking over the 10,000 view mark Rick. Only the Dude's 911T thread is ahead of you now, lol.
Old 07-29-2011, 07:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
