CaptainCalf's Avatar
Good point!
Thanks!
I would advise against that since the locktite would not be guaranteed to flow out of the space between the bearing and rod before setting which could cause very bad issues since rod bearing clearance is critical, especially too little of it.
The bearings are designed to have the perfect amount of crush, so short of catastrophic mechanical failure they will be just fine being clamped inside a lightly oiled surface.
Old 03-21-2011, 09:50 AM
In an effort to show our host my appreciation I've ordered my 1st Pelican Part!
Ordered the much coveted Engine Stand Adapter Ring
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 03-21-2011, 10:06 AM
Cylinder to head Sealing & Head Stud Options
I still need to cover the topics of cylinder to head sealing and head stud choices before I can dive headlong into this build.
After some homework I still have no idea what to do about sealing the heads to the cylinders, but think I've narrowed it down to 3 top choices:
APR
Supertec
Porsche Steel
All you engine gurus out there please let me know your experiences and what you'd recommend on both sealing and head studs.
Thanks,
RC
Old 03-21-2011, 10:14 AM
Plastigauging the crank rod journals and each connecting rod. I've read that it's good to make sure they are in spec 0.030mm to 0.088mm, but I'm worried that the bearings may deform during the process and have a greater tendency to spin. What should I do?
Thanks,
RC
Old 03-21-2011, 12:46 PM
350HP930's Avatar
Don't forget to inquire about head sealing and EFI options too Rick unless you already have your mind made up about those issues already!
Fortunately the EFI options are a lot more plentiful and less costly than they were back when I started down the path you are currently on.
As long as you are careful with them the rod bearings will be able to handle more than one clamping. The strain is well within their elastic limit so they can handle a few cycles without any issues, just make sure the rod journal has a light layer of lube so they can displace to where they want to go and that they are perfectly straight and flat in the rod before you pop the cap on and torque them.
Old 03-21-2011, 12:55 PM
As long as you are careful with them the rod bearings will be able to handle more than one clamping. The strain is well within their elastic limit so they can handle a few cycles without any issues, just make sure the rod journal has a light layer of lube so they can displace to where they want to go and that they are perfectly straight and flat in the rod before you torque them.
Great! I like plastigauge
Yep, there's lots and lots of details to work out on this slippery slope, but we'll get to them all!
Thanks,
RC
Old 03-21-2011, 01:00 PM
Bearings
Rick, use a dial bore guage for checking your rod clear. and be sure its closer to the .088mm clear. we can fire ring your head/cyls. like the 935 style do it all the time, what size bore are you going with ? that is the biggest concern with reducing seal surface area, if its 97 or 98mm thats fine but 100mm and fire rings not much area left.
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-21-2011, 01:34 PM
Mike, they are stock 3.3 930 holes that have been honed, so sounds like fire rings would work fine !
RC
Old 03-21-2011, 01:53 PM
I'll break out the bore Guage tonight
RC
Quote
Old 03-21-2011, 01:57 PM
fire ring
It should be a 97mm bore, if you have a dial bore guage torque the rods without the bearings and measure it, on those I start at 2.284 in. on the big end housing bore then put the bearings in and see what you have for bearing clear. just be sure the crank,rods, mics. are all in the same room to get the temps the same, my engine room is like a meat locker compared to the machine shop.
Mike
Old 03-21-2011, 02:30 PM
Will do and Thanks!
Mike
Old 03-21-2011, 02:44 PM
Cylinders mesurements
I went out to the garage to set up to measure the rod bearing clearances, but got sidetracked measuring the cylinders and checking roundness and taper. Before I could get to the conrods the mosquitos ran me back in the house. At least they gave me a t-shirt for the donation
Old 03-21-2011, 06:21 PM
Roundess dead on!
The shop manual says if the cylinders measure within 0.08mm of new then they are good to go. I have one new one that measured 97.060mm and all the rest were 97.070 or less. They were all round and the taper from top to bottom was 0.01mm or less. I think it's safe to say the PO took real good care of this 930!
Old 03-21-2011, 06:29 PM
350HP930's Avatar
Nice bore gauge and pics. Sorry to hear about the skeeter attack, but we are in florida after all. Probably need to add some bug repellant to the project list as well, lol.
Old 03-21-2011, 07:01 PM
AlfonsoR's Avatar
Nice build. Good luck.
Old 03-22-2011, 07:36 PM
got the spray!
now I have the rods torqued to 37 ft-lbs with the old bolts, but can't find my micrometer to set up my bore gauge so big end clearance checks will have to wait for now...maybe I'll measure the slugs and start matching them with cylinders
Old 03-23-2011, 05:35 AM
Rods
Rick, If I understand your last post correct you can't use your old stock bolts to get a measurement, the ARP or whatever non stock bolts are torqued to a different value and will change the housing bore dimensions IF they were resized with the ARP bolts. So that said if they were resized with the stock bolts the same applies to just installing the ARP's won't work. They have to be resized with what you will be using, the ARP can be stretched several times without an issue, they want you to cycle them several times before final torque. Plus it most likely will be something your regular dialbore guage won't be sensitive enough to detect the out of round condition, the guage on a rod machine has a sweep of .010 in. total instead of .050 or .100 in.
Old 03-23-2011, 06:02 AM
350HP930's Avatar
+1 on leaving the ARP hardware in the rods. They can handle the stress cycles and will create the clamping force the rods were resized for.
Old 03-23-2011, 06:10 AM
Thanks Mike! I had no idea the APRs wanted to be streached/cycled before final intallationbut that's good to know. Glad you're on my team
I'll take the old bolts out and replace them with the new APRs
My gauge is sensitive to 0.0004"
RC
Old 03-23-2011, 06:11 AM
Thanks Tony, I'm counting on you guys to keep me straight!
I'm take'n it real slow so I don't mess up
RC
Old 03-23-2011, 06:20 AM
