-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
350HP930 12-02-2011 09:00 AM
Save yourself the trip, I'll use it as an excuse to come by and see everything in person, lol. ;)
CaptainCalf 12-02-2011 09:00 AM
Das roll bars
Anybody got a set of these laying around that they wanna get outta the garage:)
http://forums.pelicanparts.com/uploa...1322845221.jpg
CaptainCalf 12-02-2011 09:03 AM
cool, I've got a new keg of Celebration made by Sierra Nevada that's callin your name:p
CaptainCalf 12-03-2011 07:54 PM
Sound/heat barrier installed
i decided to install a nice layer of heat/sound protection before installing new carpet:D
http://forums.pelicanparts.com/uploa...1322970861.jpg
CaptainCalf 12-05-2011 09:09 AM
headliner is going in
Installing the headliner is a slow process for me, but it may just turn out looking good if I don't cut it too short:rolleyes:
http://forums.pelicanparts.com/uploa...1323104938.jpg
http://forums.pelicanparts.com/uploa...1323104948.jpg
CaptainCalf 12-05-2011 06:29 PM
Rennline pedal kit installed
amazing what a little bit of bling can do:D
http://forums.pelicanparts.com/uploa...1323138544.jpg
CaptainCalf 12-07-2011 10:00 AM
Das Roll Bar
FedEx delivered my new roll bar today and surprisingly it fits in my car, so off the powder coater:)
http://forums.pelicanparts.com/uploa...1323280808.jpg
CaptainCalf 12-08-2011 06:52 PM
sunroof sound/vibration baffles
The 2 original baffles between the headliner and the sunroof motor are toast. The fiber boards are moisture damaged and the foam is falling apart.
Ordered 2 new ones from our host and was told they are not available from anywhere, so I'm making my own outta aluminum and bio foam that will be moisture proof!
http://forums.pelicanparts.com/uploa...1323398940.jpg
http://forums.pelicanparts.com/uploa...1323398964.jpg
http://forums.pelicanparts.com/uploa...1323398988.jpg
http://forums.pelicanparts.com/uploa...1323399013.jpg
http://forums.pelicanparts.com/uploa...1323399036.jpg
http://forums.pelicanparts.com/uploa...1323399064.jpg
http://forums.pelicanparts.com/uploa...1323399094.jpg
http://forums.pelicanparts.com/uploa...1323399113.jpg
CaptainCalf 12-13-2011 08:40 AM
New Window Gaskets
While waiting for injectors, sensors and wire harness before I can fire up the motor I'm still working on an interior refresh and I gotta say that no matter what folks charge to install new window gaskets it's not enough!
I used soapy water which helped a little, but to get the trim in I had to use some 100% silicone grease. 1 window down and 3 to go:rolleyes:
http://forums.pelicanparts.com/uploa...1323794241.jpg
CaptainCalf 12-13-2011 10:16 AM
Metric Fuel Line Fittings
After searching the internet for metric fittings I found a distributor in my own back yard:D
If you ever need something like M16x1.5 to -6AN fittings check these guys out:
BAT, Inc in Sarasota, FL 941.355.0005.
http://forums.pelicanparts.com/uploa...1323800084.jpg
350HP930 12-13-2011 02:05 PM
Old rubber is the worst, especially when the ambient temps are not too hot.
Front window was replaced along with the gasket back in the early 2000's so that one will hopefully not be as bad as the others.
If they give you trouble put them in an oven set around 100 degrees. When you go to pop them in that way the rubber will be much more compliant when you do.
CaptainCalf 12-13-2011 05:37 PM
thanksSmileWavy
CaptainCalf 12-13-2011 05:44 PM
defroster vent cover
Anybody know why this thing is painted brown? I think I'll paint it brown again unless it should be black?
http://forums.pelicanparts.com/uploa...1323826953.jpg
http://forums.pelicanparts.com/uploa...1323827018.jpg
350HP930 12-13-2011 05:57 PM
Perhaps it faded to where it appears brown?
proffighter 12-13-2011 11:36 PM
Maybe because the car had brown interieur from factory;)
CaptainCalf 12-14-2011 05:50 AM
After ripping out what seemed like 25 year old black carpet and headliner I'm pretty sure the original factory color was black w/o looking it up, so looks like the defroster vent cover faded to look brown...I'll paint it black again.
CaptainCalf 12-14-2011 04:40 PM
Strut Tower Brace
New strut tower brace came in today thanks to our hostSmileWavy
http://forums.pelicanparts.com/uploa...1323909612.jpg
CaptainCalf 12-15-2011 05:32 PM
strut brace
strut brace done
http://forums.pelicanparts.com/uploa...1323999069.jpg
CaptainCalf 12-17-2011 03:56 AM
uphostery
recovered the rear side window trim bars since they will be needed to finish off the RS carpeting
http://forums.pelicanparts.com/uploa...1324122979.jpg
http://forums.pelicanparts.com/uploa...1324123004.jpg
CaptainCalf 12-21-2011 06:28 AM
Roll bars and bell crank bushings
Pressed in the new tranny bell crank bushings and picked up the freshly powder coated satin black roll bars. Now I just need to find time to finish the interior before the rest of the engine parts get here:rolleyes:
http://forums.pelicanparts.com/uploa...1324477300.jpg
http://forums.pelicanparts.com/uploa...1324477309.jpg
http://forums.pelicanparts.com/uploa...1324477592.jpg
