FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
valance base coat painted
Surprisingly the red looks like a pretty good match!
After the next project
Wow!!!
Just noticed this entire thread... haven't been on the engine rebuilding forum for quite some time until my recent acquisition... nice work. beautifully done. Now, I will follow until you get her running.
Cheers, Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Thanks Bryan, good to have you on board!
RC |
heat sheild & GT3 valance
painted the heat shield then had to cut it for the GT3 tailpipe...shouldda did that the other way around
![]() clear coat turned out so good on the fiberglass valance I didn't have to buff it at all ![]() ![]() ![]()
Thanks 5.7GT1
C2 idle valve orientation
should the arrow point up or down?
Forced Induction Junkie
The arrow indicates the direction of air flow.
Beautiful work,btw.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
In other words, pointing towards the intake plenum.
vacuum port on C2 throttle body
is this port on the back of a C2 throttle body okay for the vacuum signal for the blow off valve?
Is that port above or below the butterfly? You'd want a port below the butterfly for vacuum when the butterfly closes under boost conditions,
IC Plumbing mostly sorted
more pics
coils mounting location
this looks like a great place to mount the coils!
I have mounted the coils there on a plate worked out great. I also was using Ford EDIS modules and mounted them to the back side of the intercooler.
RC
Banned
Not that you are asking for suggestions, but if you replace the front intercooler mounts with rods and heim joints, like in the linked pic, it would clean up the look considerably . . .
What I have been doing for the last 2 years! |
