Wern't those old tranny bell crank bushings plastic? Nice upgrade if they were.
these wont be falling apart in my lifetime:p |
Look what I found under the passanger seat!
I've replaced a lot of old parts so far, but I think I'll keep this sweet old school Alpine amp for listening to the 80's on 8:)
Seriously, I think I can rig it to run about 40 watts RMS each to the two front speakers at 2.7-ohms and bridge the 2 channels left over to deliver 90 watts RMS to the rears in series at 5.4-ohms...we'll see if it's got a few years left in it or not real soon:D http://forums.pelicanparts.com/uploa...1324496714.jpg http://forums.pelicanparts.com/uploa...1324496726.jpg http://forums.pelicanparts.com/uploa...1324496738.jpg |
You gonna keep that classic and original looking blue point deck in the dash as well? That old set up did a pretty good job blasting the tunes back in the day. :)
Lol, I was but can't find any of my old cassettes:)
seats are in
by this time next week I should have most of the other EFI parts needed to finsih off the motor so I need to finish off the interior asap:rolleyes:
http://forums.pelicanparts.com/uploa...1324522987.jpg |
Very nice!!!
nice seats...do you happen to have their weight, name/model #, fabric shown...
Keep up the great work...!! Bob |
Sparco USA I decided to go with them cuz they are not expensive and are reclinable for commuting comfort:D. |
Closing in on the inerior
Lots of time to get things done during the holidays:)
Once I get the new RS door panels in I'll be done with the interior. By then I should have my new wiring harness so I should be able to finish off the motor 1st of 2012:D http://forums.pelicanparts.com/uploa...1324912427.jpg http://forums.pelicanparts.com/uploa...1324912448.jpg http://forums.pelicanparts.com/uploa...1324912471.jpg |
hey bud that Sparco knob looks uuuuuber cool
Thanks Willtell, it's easy to gloss over things like vac fittings, but they will sure cause issues on down the road if not properly connected now!
It's hard to tell from the PET for sure, but it's a shared port that has a sensor on the other nipple. Anybody know of this double nipple fitting at the base of the C2 TB and if they are for vac or not? |
i think it's a temp switch (valve) like the one on the turbo that changes disrtibutor advance once the engine is warmed up.
vac port
Looks like I just need to find out where this vac hose connects on the TB:
http://forums.pelicanparts.com/uploa...1325094872.jpg It almost looks like the thermo valve has a direct vac connection at the TB and this vac hose connects to the other thermo valve nipple. I'll check to see if the thermo valve can act as a pass through for vac...I've seen stranger things;) |
Fabbed up some new IC supports
these look pretty good for a free hand drill press & CNC machine:)
http://forums.pelicanparts.com/uploa...1325126639.jpg http://forums.pelicanparts.com/uploa...1325126690.jpg http://forums.pelicanparts.com/uploa...1325126731.jpg http://forums.pelicanparts.com/uploa...1325126764.jpg |
Any plans on keeping the A/C? We live in florida after all.
JK, I have the double belt pulley installed and figure I'll prolly go with the Griffiths aftermkt system when I start sweating next summerSmileWavy |
| All times are GMT -8. The time now is 10:48 PM. |
