X-Dash is in
The x-dash went in last night.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Ground Wire?
Can anybody tell me where this wire bolts up on the motor or gearbox? It's heavy gauge and looks like a ground wire and it's located in the right (passenger side) rear engine bay.
wire either goes to the body ground stud just outside the tunnel hole OR to the engine starter...I am not sure which though...I hope I got you closer... :-)
I live for 911 tweaks... |
Looks like one of the starter motor cables. If no battery is connected an ohmeter will tell if it's a ground cable.
Motor is in!
Got a lot done today; motor installed, clutch & throttle adjusted and 8 qts of oil poured in. Once I sort the starter I'll turn it over to see if I can get oil pressure
Awesome progress Rick!
I'm glad to see the electronic display is going next to and not replacing all the analog gauges. |
Starter wired and muffler mounted. Fresh air intake next then fire in the hole
Oil Pressure is good
Rolled the motor over with the starter w/o spark or fuel and got good oil pressure at the cam towers. However, I didn't fire it up cuz I have a leak on the motor around the oil cooler area, so gotta chase that down 1st. Just glad there's only 1 leak
Leak found
The motor mounted thermostat failed and filled the motor mounted oil cooler with cold Joe Gibbs BR and popped it like a zit! I don't know how you guys feel about this cooler, but I think it's a weak link and plan to add a 3.6L/993 filter console there instead.
I will need an oil inlet adapter, so please show me some ideas ![]() Here's an example of the Smart Racing Kit looks like: ![]()
Gutted thermostat
All the parts for the filter console conversion have been ordered and here's what the thermo looks like after I gutted it for use with the 3.6 filter console. The internals were bad rusted and had to be cut out...
maybe I missed it but what is the next project...?? Porsche I hope...:-)
![]() I looked for a 356 to Outlaw and they are hard to find, so I decided to build a custom bike instead using the old Martini colors off Moby Dick ![]() The donor bike is a generic 1999 Harley Davidson 1200C Sportster: ![]() Here's what the old school peanut tank looks like on it: ![]() Shooting for double the stock power output with STG2 flowed heads, bigger PCs, HC pistons, cams, carb, etc: ![]()
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 05-04-2012 at 05:28 AM.. Reason: add |
STG8 CV Bolts installed
Happy Cinco De Mayo!
Added locking fasteners to my CVs so there wont be an issues with bolts backing out... ![]() ![]() ![]()
Great idea! Who makes the kit?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Stage8.com
DTAFast X-Dash
Electronic dash lit!!!
![]() I used the new DTAFast CPU to prime/run the fuel pumps and found leak. Guess where...yep back side of motor, but I got it sorted, so as soon as I get the filter console I can fire it up ![]() Anybody wanna give me their brake-in insights? I'm planning to run it for a minute initially to make sure I don't have any more leaks, then do some pulls (accels & decels up to 5K rpm) to seat the rings and run in the cams.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 05-06-2012 at 04:07 PM.. Reason: add |
maybe different for a turbo motor, but, many have posted here on Pelican that to break in a new rebuilt porsche motor to do the following:
1. do as you have to start and/or turn key to hot to check for leaks on oil & gas... 2. prime oil system by cranking car w/o fuel pump running...when see oil pressure on gage @ ~1-2 bar = she is primed... 3. fresh gas in tank & oil tank filled w/ ~ 10 qts or what your system takes... 4. start motor & run for 20 min @ 2500 rpm to break in cams... 5. then take car for drive...do not exceed 5k rpms' for 1st 100 miles...accelerate up hills & when coming down hill, have foot OFF accelerator so engine is working like a brake = this puts opposite pressure on rings vs accelerating... 6. check oil level @ tank frequently = like every 25 miles to make sure a possible leak did not develope & empty your system... 7. extend your boundries more & more as confidence increases... 8. *** carry spare tools with you = plyers, screw drivers, combo wrench set, duct tape, 3 bottles of oil, ect...just in case...spare rags & towle, flash lite... Grin more & more as time goes by w/o issues... :-) Enjoy...& take pics on the road...maybe a sound clip or 2 to post up...we are dying to hear that turbo spool up... : )
I don't remember if you put in new cams or not. If the cams are new idleing right away is not good, instead you want to hold it at 2000rpm or right around there for about 20 minutes.
When I put in new cams and rockers I would have pissed off the neighbors too much doing that in the driveway so I drove it and kept the rpms right around 2000 heading for I-95. Out on the interstate it's easy to keep it at 2000rpm in 4th gear. After that you can do accelerations and decelerations below 5000rpm like you said but I wouldn't get into boost any higher than .3 to .5 bar right away. You want to change rpms and gears alot after the initial 20 minute cam run in. If the cost of oil isn't an issue I'd change the oil and filter after the first 2-3 hours of running. When you look closely at the used breakin oil in sunlight you'll probably see some superfine metal dust sparkling in it. Most of all, good luck with it and enjoy! |
Thread Tools | |
Rate This Thread | |
