LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
rsrfan's Avatar
It will be harsh, but not rattle your teeth out harsh. You will need to do something to counteract the squat that will occur when you put that much power down. In addition to the 30s, you may need helper springs...
JP
86 930/4 tribute beasty
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 04-24-2013, 04:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #881 (permalink)
CaptainCalf's Avatar
That what I was thinking...What do helper springs look like?
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 04-24-2013, 04:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #882 (permalink)
rsrfan's Avatar
You have to go to a coil over set up on the back. Cheapest is a a Rebel or Elephant sleeve kit for your existing bilsteins. Usually you want to run around 150-200 pound springs in addition to the torsion bars depending upon their size... Clint or Chuck will be able to set you up.
JP
81 sc beach beater
‘55 Belair
‘40 Ford pickup
Old 04-25-2013, 09:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #883 (permalink)
Thanks, I had no idea they made sleeve kits
Old 04-25-2013, 10:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #884 (permalink)
OEM fuel pump vs 044
The 044 pump is nearly twice the size of the OEM front pump.
Old 04-28-2013, 06:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #885 (permalink)
When I took out the front fuel pump in my '87 turbo and replaced it with a new 044 pump they were both the same thickness but the 044 was about 3/4" longer like yours appears.
You can remove the spacer between the check valve and pump. That shortens the overall length and it fits in the origonal position better.
Porsche also makes a thick rubber sleave with rubber cap that goes on the end that fits the 044 like a glove and quiets it down alot. I think it was origonal equipment on the 964 and 993. Maybe other's had it too.
With the rubber sleave the pump won't fit in the origonal pump mount but you can remove the origonal mount and push the rubber sleaved pump up in between the front cross member and the gas tank and secure it there with a long american made hose clamp.
The origonal banjo fitting fuel line still fits with it mounted like that. You may have to lengthen the wires a little and you wil have to put larger eyelets on the ends to fit over the thicker wire terminal studs on the 044.
Old 04-28-2013, 07:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #886 (permalink)
I shortened the rubber hose a little between the tank and pump and it fit fine. Found a busted rubber isolator mount so replaced that and I had to use a larger clamp, but all in all it was a nice fit. Under high boost it makes AFRs in the 11s now, so all is good with fueling now...
Old 04-28-2013, 07:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #887 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
Captain,
How on earth did you get to test "under high boost"? Might it be some spirited driving?
Enjoy the fruits of your labors....
Stay Tuned,
PFM
Old 04-28-2013, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #888 (permalink)
Captain,
LOL, can't find a road long enough for 4th gear but boosting 3rd is scary fast...thanks!
Old 04-28-2013, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #889 (permalink)
Drove to work today
It was fun putting this puzzle together, but I think driving it is more fun
My shady spot at work
Not much shade at the gym
Old 05-07-2013, 12:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #890 (permalink)
jsveb's Avatar
Looks fantastic.
Old 05-07-2013, 12:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #891 (permalink)
Originally Posted by jsveb View Post
Looks fantastic.
I'll have to rub all the love bugs off it when I get home tonight, but it should only take a couple of beers
Old 05-07-2013, 12:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #892 (permalink)
Clutch Falure
After putting about 6,000 easy non-race miles on this new clutch an inner piece broke off and decide to come out. Luckily it bound up the motor on start up and was addressed before it cause any major damage. I've asked the folks I bought it from if they'd replace it as defective since it hasn't been mistreated and still looks new.
What do you guys think? Does it look defective to y'all?
Old 02-27-2014, 12:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #893 (permalink)
sjf911's Avatar
Wow, that has to be a manufacturing flaw. Let me know if they won't take it back and you're going to junk it, I'm looking for a worn out disc to make a transmission locking tool.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 02-27-2014, 12:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #894 (permalink)
Will do
Old 02-27-2014, 12:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #895 (permalink)
PrimeMvr's Avatar
Sure looks like a defect to me. Curious...are you able to get the trans out without dropping the engine on one of these things? I've always dropped them together, but going through all the disconnects if you only needed to do a clutch stinks.
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 02-27-2014, 02:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #896 (permalink)
Yep, gotta drop it...labor of love for most good 930 mechanics.
Old 02-27-2014, 02:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #897 (permalink)
New clutch, corner balance and alignment all done...Thanks to Micky at European Performance!
I'll miss this one very much, but we gotta sell it cuz we're moving from the burbs into the city so we're loosing our big 3 car garage...
I'll post it up for sale offically tomorrow here on Pelican and in the other usual locations, but if anybody here who's watching this thread is interested please shoot me a PM & thanks for everything...it's been a great ride!
RC
Old 03-31-2014, 11:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #898 (permalink)
FS 1987 930 in Lithia, FL
Old 04-03-2014, 07:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #899 (permalink)
ChrisP911's Avatar
What was the final HP after you installed the 044 fuel pump
Old 11-11-2014, 11:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #900 (permalink)
