-   -   The Beautiful Puzzle: 1987 3.3L 930 EFI Build (http://forums.pelicanparts.com/911-engine-rebuilding-forum/598040-beautiful-puzzle-1987-3-3l-930-efi-build.html)
CaptainCalf 05-06-2012 06:20 PM
Thanks Guys! New cams and rockers refaced, so I'll do the 20 min at 2K rpm then I'll seat the rings.
Then I'll change oil from Gibbs BR to Brad Penn 20w50.
CaptainCalf 05-07-2012 06:18 AM
JB Racing oil inlet adapter
Custom made parts like this 16-AN oil inlet adapter made by JB Racing make life so much easier...thanks Big MikeSmileWavy
http://forums.pelicanparts.com/uploa...1336396628.jpg
CaptainCalf 05-07-2012 11:14 AM
1st oil change
Just got a case of BP 20w50 green oil in, so I'll just need to grab a couple of filters and I'll be ready to change out the BR oil after the break-in.
http://forums.pelicanparts.com/uploa...1336414360.jpg
MBruns 05-07-2012 11:33 AM
break in oil
How quick do you plan on dumping the break in oil ? I would not drain it before you have done some dyno maping and some runs with some boost, your rings will seat better if you do, the JGR oil is good for about 50 pulls with a 800 plus Nascar cup engine before it gets beat up so don't be afraid of it.
Mike Bruns
CaptainCalf 05-07-2012 11:42 AM
Mike Bruns
Thanks Mike, I'll make sure I run the Gibbs BR for a good long while to seat those ringsSmileWavy
willtel 05-07-2012 12:44 PM
Are the fuel and ignition maps ready to go for break in?
I've always wondered how one is supposed to tweak and tune these things on a fresh engine.
CaptainCalf 05-07-2012 12:50 PM
Are the fuel and ignition maps ready to go for break in?<br>
<br>
Yes, Wayne over at TPS Products setup the ECU so it's loaded for bear!
CaptainCalf 05-08-2012 10:22 AM
993 filter console is in
Here's a pic of the filter console that replaces the motor mounted oil cooler on the 993 and a random pic from downunder the car while everything is still clean and dry:D
http://forums.pelicanparts.com/uploa...1336497701.jpg
http://forums.pelicanparts.com/uploa...1336497713.jpg
911 tweaks 05-08-2012 10:37 AM
...is it me or do those pipes look sexy...?? :-)
CaptainCalf 05-08-2012 10:44 AM
Yep, there's just something about a nice set of pipeshttp://forums.pelicanparts.com/suppo...s/beerchug.gif
CaptainCalf 05-08-2012 05:47 PM
oil inlet conversion tube
Here's a pic of the whole setup for the oil inlet conversion. Fit is a little long due to the 30mm to 16-AN to 16-AN couplers, but instead of cutting it down I used the extra length to tie it downSmileWavy
http://forums.pelicanparts.com/uploa...1336524340.jpg
CaptainCalf 05-09-2012 07:57 AM
Slow leak at rt fuel rail
Now that I've got the oil cooler conversion done I've found a small leak at the rt fuel rail (4-5-6) at the joint at the back going to the regulator. The male convex compression end on the rail had been clamped down hard at sometime in it's previous life creating a grove that allowed fuel to escape under pressure, so I've pulled it off and took a flat bastard to it and will try it again.
If it still leaks then I'll be needing one of these, so if anybody has one laying around that they can part with pls let me know:
http://forums.pelicanparts.com/uploa...1336575272.jpg
willtel 05-09-2012 09:00 AM
Another option would be to saw off the bad fitting and braze on AN fittings.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/613025-carrera-intake-fuel-line-update-my-efi-conversion.html
CaptainCalf 05-09-2012 09:32 AM
Originally Posted by willtel (Post 6737578)
True and we are fortunate here in the Tampa area to have Amazon Hose nearby and they can make short work outta fixing it for me if neededSmileWavy
CaptainCalf 05-09-2012 06:15 PM
Fuel rail fixed
No more leaks!!! Don't ever underestimate the power of a good flat bastard:D
willtel 05-11-2012 04:41 PM
Fire it up!
CaptainCalf 05-11-2012 05:06 PM
Originally Posted by willtel (Post 6742604)
Fire it up!
That's the plan and I should have a video of it shortlySmileWavy
CaptainCalf 05-13-2012 07:19 AM
First Fire Video
Here's a vid of the cam run in...she's running rich on the generic map, but better rich then lean:D
1987 Porsche 930 New Cam Runin - YouTube
PFM 05-13-2012 01:52 PM
I think I can hear the celebration from here!
Stay tuned,
PFM
350HP930 05-13-2012 01:55 PM
I hope the only reason we haven't seen more yet is that you'v e been busy driving and/or tuning it, lol. ;)
