Thanks Guys! New cams and rockers refaced, so I'll do the 20 min at 2K rpm then I'll seat the rings.
Then I'll change oil from Gibbs BR to Brad Penn 20w50.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
JB Racing oil inlet adapter
Custom made parts like this 16-AN oil inlet adapter made by JB Racing make life so much easier...thanks Big Mike
1st oil change
Just got a case of BP 20w50 green oil in, so I'll just need to grab a couple of filters and I'll be ready to change out the BR oil after the break-in.
break in oil
How quick do you plan on dumping the break in oil ? I would not drain it before you have done some dyno maping and some runs with some boost, your rings will seat better if you do, the JGR oil is good for about 50 pulls with a 800 plus Nascar cup engine before it gets beat up so don't be afraid of it.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Are the fuel and ignition maps ready to go for break in?
I've always wondered how one is supposed to tweak and tune these things on a fresh engine. |
993 filter console is in
Here's a pic of the filter console that replaces the motor mounted oil cooler on the 993 and a random pic from downunder the car while everything is still clean and dry
...is it me or do those pipes look sexy...?? :-)
I live for 911 tweaks... |
Yep, there's just something about a nice set of pipes
oil inlet conversion tube
Here's a pic of the whole setup for the oil inlet conversion. Fit is a little long due to the 30mm to 16-AN to 16-AN couplers, but instead of cutting it down I used the extra length to tie it down
Slow leak at rt fuel rail
Now that I've got the oil cooler conversion done I've found a small leak at the rt fuel rail (4-5-6) at the joint at the back going to the regulator. The male convex compression end on the rail had been clamped down hard at sometime in it's previous life creating a grove that allowed fuel to escape under pressure, so I've pulled it off and took a flat bastard to it and will try it again.
If it still leaks then I'll be needing one of these, so if anybody has one laying around that they can part with pls let me know:
Another option would be to saw off the bad fitting and braze on AN fittings.
Carrera Intake Fuel Line Update For My Efi Conversion |
Fuel rail fixed
No more leaks!!! Don't ever underestimate the power of a good flat bastard
Fire it up!
That's the plan and I should have a video of it shortly
First Fire Video
Here's a vid of the cam run in...she's running rich on the generic map, but better rich then lean
![]() 1987 Porsche 930 New Cam Runin - YouTube
PFM
I think I can hear the celebration from here!
Stay tuned, PFM
Stay Tuned, PFM |
I hope the only reason we haven't seen more yet is that you'v e been busy driving and/or tuning it, lol.
