350HP930's Avatar
The pros and cons of twin plugging a 930 are certainly debatable and many of them are discussed in the following old thread . . .
Advantages of Twin Plug
When the engine is heavily loaded CHT is going to be one of the largest contributors to detonation which is why I think the known disadvantages of losing several square inches of head cooling surface area isn't worth a small tweak in ignition timing the twin plugging might give you.
Old 05-19-2011, 09:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
CaptainCalf's Avatar
+1
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD
1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD
2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha
Old 05-20-2011, 07:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
progress!
looks like a front end rebuild is due
1987 930 Front End Rebuild
Old 05-22-2011, 05:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
PFM PFM is offline
PFM
PFM's Avatar
CHT + Boost = Ceramic Coating
Stay Tuned,
PFM
Stay Tuned,
PFM
Old 05-22-2011, 06:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
Measuring Valve Spring Heights
My plan is to get the heads built up this week, so I have a couple of questions. Are all 930 valves springs set to 34.5mm and what do you use to measure them with while shimming?
Also, do I really need a $50 tool to measure the height?
Pelican Parts - Product Information: PEL-TOL-P228
Thanks,
RC
EDIT: I'll be running SC cams so that may affect the height wanted too and I read somewhere a builder recommended 33.5mm heights for 930s...
Old 05-24-2011, 06:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
sanded shroud
ready for paint
Old 05-24-2011, 05:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
rockers
Rocker refurbed by: Dougherty Racing Cams
Thanks John, they look better then new!
RC
Old 05-25-2011, 06:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
What Valve Spring Height???
I have a set of Super Cup cams, which I think are John's grind cuz they are stamped DRC.
I need to know valve spring stack height for new valve springs, so if anybody knows pls help
Old 05-26-2011, 06:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
350HP930's Avatar
The rockers look great Rick.
As far as the recommended spring heights and related info, if its not on the cam card I would suggest contacting John for the details since you are the owner of his product now after all.
Old 05-26-2011, 06:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
I did ask him to chime in when he gets time cuz I don't have the cam card. However, I found what looks like the lift/timing on his website:
SC on Turbo int/exh
Duration at 1mm = 236/224
Duration at 0.050" = 228/218
Lift = 0.450"/0.395"
lobe seperatrion angle = 113
lift@overlap setting 1.4-1.7mm
Old 05-26-2011, 06:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
Ken911's Avatar
he's good i lost the cam timing card from my ssc cams and last time i had the engine apart i called him and he knew right away what i had and what to time the cams at.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 05-26-2011, 07:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
camgrinder's Avatar
Cam Timing is set at 2.0mm. Valve spring open height 1.5 mm from coil bind. IF you plan on shifting over 7000 rpm, consider an aftermarket valve spring.
http://www.drcamshafts.com/profiles/supercup.htm
John Dougherty
Old 05-26-2011, 08:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
Thanks John, I'll set them at 35.5mm +/- a frog hair and the warranty on these 2005 cams doesn't start till they are installed, right?
Old 05-26-2011, 08:56 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
good progess today
Old 05-29-2011, 04:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
today's progress continued
Old 05-29-2011, 04:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Next heads
Old 05-29-2011, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
rsscotty's Avatar
I get nervous when I see a nose bearing without the o-ring and the bearing case dowel installed.
Old 05-29-2011, 07:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
Good eye and what you can't see is the missing dowel pin on order too
Old 05-30-2011, 01:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
Nice edit and you missed a couple other things too. Let me know if you see them?
RC
Old 05-31-2011, 11:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Heads getting assembled
2 down and 4 to go
Old 06-02-2011, 05:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
