Movin on...heads done ring gaps next
Got 3 of the slugs ringed tonight and using a gapless CR in second groove.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha |
Progress this weekend
While waiting for some green through bolts o-rings I removed the ball joints and control arm joints and added a missing spacer to a spindle up front. Also greased rack & pinion and replaced all A-arm and sway bar bushings up front.
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 06-13-2011 at 06:27 AM.. Reason: spell |
That car's going to be better than new by the time you are done with it Rick, lol.
clean fan
once i started rubbing the fan I couldn't stop
![]() ![]() I'll clear coat it so I wont have to do it every other week
LOL, I've been down the road you are already on with that fan.
Word of warning about trying to clear coat it. Magnesium alloy is notorious for being difficult to paint and paint coatings debonding and flaking off over time. For that reason I'd highly recommend just enjoying the shiny surface till the flat platina slowly but surely returns. |
Forced Induction Junkie
+1 Amen brother!
Fan and housing now showing the "classic" patina. BEFORE:
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Hey Dave, you forgot the after pic, lol
I think we all know what the after pic looks like
![]() I'll try some 2K epoxy primer to seal it. I really wanted the lighter grey color anyways
Yeah, pick a fan.....any fan and you'd probably be spot on as to the condition of mine. By the time rebuilt engine was broke-in, the patina had returned in all its glory.
When sanding painted aluminum I've seen 2 different color layers of primer under the color coat. Aluminum street signs are an example of that. or... just powdercoat it
Yup, +1 since I was going to warn you to google 'magnesium alloy painting' since a chromate based surface prep treatment is essential to anything sticking to it.
Depending on what kind of abrasive you used an acid wash or media blast may also be required since contramination from other metals and some ceramics will also reek havoc with trying to make something stick to it. Quote:
Fans
The bottom line is that the fan moves so much air (and sand) that nothing will stay, over the years we have found powder coating does the best, but you have to skin the OD on the lathe and mask areas to keep the build up of material out of those areas, etc... and even then its not going to stay on the leading edges.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Yeppers, if I were you Rick I would just keep it plain metal.
I'm biased, but I think unblemished grey mag looks better than any artificial coating anyways. There will be a nice, big, shiney intercooler setting above all of that if you feel the need for some permanant bling-bling in your engine compartment, lol.
MBruns for President
I personally am a fan of powdercoating in Florida. Especially anything al or mg that tends to break down with the salt that we have in our air.
I know that it will wear over a period of time - but I'm much rather blast and repaint than buy another fan or housing.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
If I remember correctly Jeremy you live right on the water which tries to corrode anything you own that is metal.
At least rick lives out in the sticks and I'm pretty sure will keep his car in a garage, so he has much less reason to be concerned about corrosion, especially once the patina forms. |
![]() I think I'll paint it with WD-40 and be done with it!
Viton through bolt o-ring stumpper!
Okay, so I'm ready to seal up the cases and look around for some nice green viton rubber orings, but instead I find a nice set of blue silicon orings that came with the gasket sets. No prob, I went to our host's catalog and ordered the GREEN vitons. They came in today, but are BLUE! I double checked the part# and it's correct, but they are still blue
![]() I got to looking at these new blue orings and I'm no silicon expert (oring or implants), but I've seen a few and these babies look like rubber to me and not silicon. Can it be true that I have a set of viton orings that are blue? If so, that will confuse a lot of folks who are looking for green only to have blue ones show up ![]() ![]()
Hmmm - blue ... It's been years - but I remember the viton being green... strange - and always fun - too keep you up an night...
Mystery solved...EDIT: supplier sent Pelican the correct viton rubber o-rings, just wrong color, so I'll be using these afterall
![]() EDIT: Not returning the blue orings for green ones. Part#s were all correct on packaging just wrong Edit: COLOR orings... RC
FS 1987 930 DTAFast EFI w/Electronic Dash, 17x9x11" Lindsey Racing Fuchs, Andial 8.39 R&P, C2 Intake, SuperCup Cams, Flame Ringed Heads & Cylinders, TurboKraft Full Bay Intercooler, RearlyL8 Twin Scroll Headers, Big Bullseye Twin Scroll Turbo...SOLD 1999 Harley Davidson Custom 1250 Hardtail Bobber..SOLD 2014 BMW X6M, 2012 BMW 128i, 2014 GMC Sierra, 2015 Cobia 237 Center Console 300hp Yamaha Last edited by CaptainCalf; 06-15-2011 at 11:55 AM.. Reason: update |
