up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Stroker 911 ; Rod Length : Stroke Ratio - Making the 911 Engine W I D E R
I have been thinking.
For the same efficiency (or VE), which is usually dictated by drivability requirements (see: "Why You Don't Want to Drive Race Engines in Traffic"), there are really only two ways to make more power:
1) Displacement
or
2) Forced Induction
Not getting into forced induction right now, let's talk about displacement.
It's simple : Bore and Stroke and the number of cylinders.
Our 911s have limits on how big we can make the cylinders before the walls get too thin. So we turn to 'Stroke'.
As far as most engines are concerned, 911s are very oversquare (much bigger bore than stroke) and that generally makes an engine inclined to rev.
If we try to lengthen the stroke, the rod length/stroke ratio can become a problem, because we have a fundamental maximum width that the engine can be.
The 2.0/2.2: 130mm rod on a 66mm stroke = 130/66 = 1.97
2.4/2.7/3.0 : 127.8mm rod on a 70.4mm stroke = 1.815
3.2 : 127mm rod on a 74.4 stroke = 127/74.4 = 1.707
3.6 (Air-cooled) : 127mm rod on a 76.4 stroke = 127/76.4 = 1.662
GT3 (127.8, 130, 138mm rods) = 1.673, 1.702, 1.806 respectively
As you can see if we tried to build a 3.6 with a RLSR (Rod Length:Stroke Ratio) like a 2.0L, we would have a 150.5mm rod, which would mean the engine would have to be about 2" wider (23.5mm on each side).
Porsche seems to believe that its "Endurance" rod should be 138mm on a 76.4mm stroke, for what are believed to be wear/durability reasons. [RLSR's nearer to 1.5 induce much more piston side-loading and greater piston accelerations exacerbating wear.]
Of course, the discussion about *WHICH* RLSR to use is more complicated than I am wondering right now, I am just curious, if we desired, say, a 1.7:1 RLSR and wanted a longer stroke, how much wider can we make the 911 engine, and what other issues would we run into?
-Taller Cylinders
-Spacers for the chain boxes
-Longer chains
-Modify the engine tin
-What else?
Do we have interference with the oil pump ? What is the maximum we can do here? And short of custom cranks, how far can we push a standard 964 or GT3 crank in terms of stroke? I think I have heard about 78.x mm but is that verified? Could we do more if we used smaller rod bearings?
Right now, if 78mm is possible, with a 105mm cylinder (possible) you can make a 4.05L motor! But to get a 1.7 RLSR, we would need to widen 6.4mm on EACH side the engine to use a 132.6mm rod.
Looking forward to your replies!
Scott Kinder
kindersport @ gmail.com
Old 08-04-2011, 01:06 PM
BURN-BROS's Avatar
Originally Posted by YTNUKLR View Post
Do we have interference with the oil pump ? Looking forward to your replies!
Yes. Carrillo wants you to massage the pump on a 3.6 with their rods. The NEW GT3RS 4.0 oil pump has apparently some clearancing although I have not seen it in person.
As to the cranks, the limiting factor is the bore spacing that porsche used. Some guys have tried to overstoke but reliability ultimately falls short.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 08-04-2011, 04:30 PM
YTNUKLR's Avatar
Would that be the CMW 82mm Billet Crank? Are there others on the market?
Thanks Aaron
Scott Kinder
Old 08-04-2011, 04:33 PM
Max Sluiter
Flieger's Avatar
Yep, crank looses rigidity- shifts the rpm where flywheels shed down into the more frequently used region, if I understand correctly.
Old 08-04-2011, 06:46 PM
Walt Fricke's Avatar
I know of at least one 2.8 long stroke RSR motor (not factory RSR parts) which got a "better" RS ratio by just lengthening the rod. Had to section the plastic engine cover to extend it some, use thicker cylinder base spacers, make chain box spacers, longer chain (should be simple to do that) or shorter idler gear, and something to deal with the carburetor actuation system - maybe just lengthened the cross rod. Don't know what they did about head studs (this pre-Supertec).
There is a guy racing a 4.0 air cooled 911 motor. Works very well indeed, so that displacement can be achieved.
Old 08-04-2011, 11:48 PM
BURN-BROS's Avatar
Thanks Aaron
I have heard less than stellar results when stroke gets too much. I could not comment on who's product that may be, but it's more a limitation of our engines that produce weaker cranks as stroke goes up. Porsche did not have a big window in regards to harmonics. The cranks need at least 1mm more material on each side of the journal to sufficiently strengthen the crank. However if you build a big low rpm moster and keep the rpms low(6000rpm) then that could be a viable engine.
The new DFI engines are much taller with the anticipation of more stroke in the future. I am not sure on the bore spacing.
Burnham Performance
Old 08-05-2011, 07:17 AM
Max Sluiter
Flieger's Avatar
Jim Copp with the POC runs a 4.2 in his '71 racecar, if I remember correctly. It's got lots of trick parts, top secret of course.
Old 08-05-2011, 10:57 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We built a 4.0 using a GT3 crank and rods, 993 case 964 heads with titanium valve and NL Nickies.The engine ran 200hrs before it's first freshen up. The RPM was limited at 7400.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-05-2011, 06:52 PM
Henry
Why 964 heads instead of 993 heads? Because it is what the customer had?
Did you use the 993 cam carriers? Those look like they are so much easier to work with when installing the rockers, plus they can't leak out past the shafts.
Old 08-05-2011, 07:01 PM
Mostly parts availability.
Henry Schmidt
Ph: 760-728-3062
Old 08-05-2011, 07:06 PM
jmz jmz is online now
jmz's Avatar
...searching up old threads on odd ball 2.8 builds cross rod had a splice welded in.
Rods are really long btw.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 03-05-2019, 06:09 AM
wider motor
When I have done this I get my parts from Peter Dawe at Dawes Motorsport.He has the spacers and different size idlers to make it happen.I use a 132mm rod on 66mm crank with no spacers.Just a different pin height for the piston for a 2.8.Fred
Old 03-05-2019, 08:07 AM
jmz's Avatar
...I was thinking about calling Peter. My engine was just torn down. I believe Peter built it originally. Rods I believe are 139.8 mm. This is on a long stroke engine.
Old 03-05-2019, 09:55 AM
[QUOTE=YTNUKLR;6177153]I have been thinking.
Read with interest.
Agree to a point but not absolute.
I am happy to give my opinions and share my experiences when solving a problem, but this is right in our wheel house and our core business. To offer up what we do in situations like this would be giving away our IP.
However, I would suggest you don’t disregard working on your engine’s efficiency altogether. Looking at making your engine more efficient doesn’t necessarily mean you are going to make it non-street able.
You will find that there is an amount of HP that can be influenced before adding displacement. Making sure every clearance is correct, every part is in spec and closer to the minimum tolerance, lowering engines friction with coatings and micro polishing, using lighter internal parts, lowering any forces that are often taken for granted, all very important in clawing back lost power in running your engine.
Controlling the engine harmonics, so that the valve timing stays where it should through out the engines RPM range, making sure that each cylinder outputs the same torque number amongst many other areas that should be given attention.
Give these some attention and you will be surprised how much added performance you will gain.
Making some positive changes here will only help when you do add to the engine’s displacement.
Old 03-05-2019, 05:26 PM
Thumbs up making it right
Neil is correct.The devil is in the details.Installed valve. the heigth should be the same.Valve spring height should be set.The pressure on the gauge for the installed heigtht of the spring should be equal.Ntow you are started. I just took apart 2 3.2 ENGINES and the outer spring is installed an average of 5 times upside down with the progressive outer spring upside down.To the point responding rockers had pitting at the top lift point .Be careful out there
Old 03-06-2019, 06:17 PM
On my case, we can make the "thickness" of the case...i.e. the dimension from the cylinder spigot face to the case parting line SIGNIFICANTLY thicker than stock. We have over 1/4" of material to play with here.
We did that because of two reasons: 1) to give us enough material to ensure true flatness and 2) for the eventual customer that would want way more stroke or lower compression for an insane turbo build.
Old 03-07-2019, 06:45 AM
Faapgar - tell us more about installing valve springs upside down. The ones I have used -- stock, and Aase -- look symmetrical to me, and I don't recall anything in the Factory manual about this.
Who makes progressive springs? Where do you want them to be strongest - at peak so the rocker doesn't fly off of the cam? Or at closure, so the valve head doesn't bounce?
Old 03-09-2019, 11:48 AM
BURN-BROS's Avatar
Hi Walt, outer stock spring is progressive. Tighter coils are at the spring seat.
Burnham Performance
Old 03-10-2019, 10:00 AM
Springs
Walt,Aaron is correct.You have to look close.If it is not a machine shop that does many Porsche heads it can be easy to miss.When ever I take a motor apart I check the valve springs and look at the head nut washers to see if they are installed right side up to see if the motor has ever been apart before.It is just another little thing that a lot of people miss.Fred
Old 03-10-2019, 10:17 AM
To keep this discussion focused on 2.8s and Henry's work of art and so on, see new discussion: Progressive Valve Springs.
Old 03-11-2019, 03:43 PM
