Soda blast P&C?
Good evening brain trust!
I am well into my first tear down of a stock 3.0 from an 83 SC. The pistons and cylinders look great except for some carbon in the ring lands and a bit on the top edges of the cylinders. The heads cleaned up so well with soda blasting that I want to do the same to the P&Cs but I wanted to check with the experts first in case this is not a good idea for the cylinder walls or piston skirts. Thanks for your valued input! Steve
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD 10 997.2 Cab - Speed Yellow 83 SC Cab - Guards Red [SOLD] 17 NSX - Nouvelle Blue |
I use low pressure (60 PSI) soda blasting to clean all my pistons and the external surfaces of all my cylinders.
Scotchbrite is the best cleaning/de-galzing system for the cylinder bores.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
soda won't hurt anything.
Certified Pre-Owned
--->Make that WHITE Scotchbrite.
'84 Carrera Coupe |
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Steve - my home brew soda blasting was so gentle that I could (and often did) blast my fingers without embedding any soda in or otherwise harming my flesh.
At that low impact range, is this really going to damage Nikasil? Not that I'd expect to blast the insides of a cylinder, because they don't need it anyway. Is a proper soda blaster of much higher impact velocities? |
Walt,
The sharp edges of the commercial media can damage the bores with sufficient pressure. Our soda cleaner does an excellent job of removing carbon, dirt, rust and even powder paint so I know it can etch a Nikasil bore. I'd experiment with a piece of aluminum and inspect it under close magnification to be sure.
Certified Pre-Owned
Does anyone have a recommendation on mesh size for the soda needed when cleaning up cylinder heads? (mesh size would be on the bag)
'84 Carrera Coupe |
Mesh size? Commercial soda media? I got mine in bags from Costco. For baking and whatnot.
Perhaps this is not aggressive enough for carbon. Did a great job of cleaning gunk off of an aluminum tranny case, though, getting into the nooks and crannies. Made a mess of my driveway. Next time I start making this mess I will dig into my box of junk parts. I've got some pieces of exploded Nikasil cylinder that would be ideal for such a test. Of course, my spouse has trouble understanding why I hang onto some broken parts. |
ASE Master Tech - 35 yrs
does that also mean a ball-hone is verboten on nikasil?
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
